XJ8 (X350) 3.6 Engine Upgrade to a 4.2 Supercharged
Old 03-26-2019, 02:30 PM
michaelrreid1's Avatar
Default XJ8 (X350) 3.6 Engine Upgrade to a 4.2 Supercharged
Has anyone undertaken this modification?
It this engine swap straightforward if you have a complete engine with ECU?
Old 03-26-2019, 03:41 PM
Received 1,423 Likes on 1,066 Posts
Nope
Old 03-26-2019, 03:59 PM
Originally Posted by abonano
Nope
Nope you haven't tried it?
Or
Nope, it was not straightforward, but you managed it?
Old 03-26-2019, 04:07 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Nope it is absolutely not straightforward for some pretty good reasons and I have not tried nor would I.
It would probably be less expensive to buy a V8 X350.
michaelrreid1 (03-27-2019)
Old 03-26-2019, 05:26 PM
Received 4,454 Likes on 2,426 Posts
You can purchase a complete, good, running XJR for less than what it will cost you to convert a 3.5 to a 4.2 s/c
The following 2 users liked this post by Cambo:
michaelrreid1 (03-27-2019), motorcarman (03-26-2019)
Old 03-26-2019, 07:28 PM
Mark in Maine's Avatar
NOPE
Old 03-27-2019, 04:12 AM
EsRay's Avatar
Michael, by way of some examples, the Wiring Harnesses, Cooling Systems, Uprated Brakes, stiffer Air Shocks and twin fuel pumps are only some of the dissimilarities…..
Old 03-27-2019, 05:38 AM
Partick the Cat's Avatar
... + Instrument module (tachometer)
Old 03-27-2019, 07:30 AM
JagV8's Avatar
Received 4,530 Likes on 3,940 Posts
+1 What Cambo said.
Old 03-27-2019, 05:03 PM
Or
Nope, would never attempt, period.
Old 03-28-2019, 06:12 PM
Wingrider's Avatar
Ambitious idea, & way more doable if we were talking about G M.
Even Ford, or Chrysler, would have to be easier than any British car.
With the complex electronics they might be a lot harder to do, than before.
Old 03-28-2019, 11:21 PM
If Cambo, Jakra_1, and abonano, won't touch it, than it probably cant be done.
Old 03-29-2019, 04:28 AM
Originally Posted by Mark in Maine
If Cambo, Jakra_1, and abonano, won't touch it, then it probably cant be done.
Yep, +1 on that.
labans
09-20-2021 08:56 PM
winefan94920
10-16-2016 02:52 PM
winefan94920
03-14-2016 07:58 PM
XJsc-guy
06-14-2015 03:49 PM
09sleeper
07-06-2014 10:20 PM
Quick Reply: XJ8 (X350) 3.6 Engine Upgrade to a 4.2 Supercharged
