I've replace the coils spark plugs fuel regulator cleaned the pop sensor an throttle body. It's got a fully charged battery tried the hard reset an the soft one where I just unhook the negative side an turn the key. Waited the required amount if time both times. Bought a really nice icarsoft multisystem car diagnostic tool lr v3.0, went thru the whole check system an read an cleared the codes. Most were u important driver side seat out of adjustment
Now it's showing a ignition run/accessory circuit failure? Please help me This is my tool an the code
Those coil pack leads from the firewall are typically small and frail. Check those wires near the coil packs to make certain that they're not shorting or grounding out.
I purchased the online xj8l manual an will be running this down. If anybody has any other ideas please feel free to post.. thank you
