XJ8L--Need instructions on how to remove center consol
Chuck Schexnayder (01-27-2017)
If you have rear aircon the contol panel needs to come out too:
Lever the wood trim off
Remove the 6-8 little screws
Unplug the controllers
Unfasten the small wire loom that is clipped to the steel bracket that runs across the opening
The rear console screws for this varient are under the foot exhaust grilles as opposed to the rear pax face vents, pop the grille off each side and you'll see the torx bolts
Here is a procedure with pics. It also has a link to it of the procedures I wrote to install an aftermarket radio with bluetooth in it
Jaguar XJ8 X350 Center Console Removal
