XJR brakes on XJ6?
I retrofitted the post-2006 X350 XJR brakes to my 2004 3.0 XJ6. Those are the non-Brembo ones that are still used on the current X351 XJ and some others like the XF. You can buy them OEM in unfinished, red, black and silver, or paint them (I painted mine quartz grey to match the car). The calipers were a direct swap, but you will also need new heat shields and brake hoses as the port position changes. You should also replace the caliper fixing bolts rather than reuse them.
My reason for changing them was because driving alongside my XJR and X351 I was always annoyed at how badly the XJ6 stopped in comparison. It wasn't dangerous; just a bit unnerving when you are used to stronger braking. The consumables were also cheaper last time I checked as they are still current parts.
scottw
05-19-2016 02:43 AM
jimlombardi
11-06-2012 12:30 PM
