xjr engine knock at high revs
04 XJR with 114000 kilometers. Runs fine at low revs, but as revs climb to about 4000, the engine loses power and knocks (rattling noise.) Restricted engine power light came on a couple of times before changing spark plugs (NGK Iridium.) Drivability improved with new plugs, but high rev knock still there. Any suggestions?
Uhhh, can you say catastrophic failure? Sounds like rod or main bearings to me.... That is a guess without listening to it. But I've seen it before. Only at 4k, huh? Are you sure? No noise at idle or through the RPM range? Could also be valve train, chain tensioners, chains, etc, etc, etc. But on an 04, chain tensioners, and chains rarely scream out for mercy. Valve/cam issues are even more rare. Did you overheat it at one point? If you did, you probably put that engine to sleep. Nighty night.
Hey Po,
Interesting topic, I was just kicking this around on another thread.
Have you seen many 4.2 failures? Any particular patterns to look for? There was one guy on here who lost a primary chain when one of his intake cams seized at the front journal. Is that one you have seen/ heard of? Thanks, from outside the loop.
Andy
Andy
The only time I've seen the 4.2 die is when Mr. Customer develops a coolant leak; ie: reservoir, thermostat housing, or water pump, and he keeps on truckin'. Well you know the end result.....she eventually relents, and the party begins. Knocking, or I've even seen a complete, and yes a complete meltdown of the engine. I mean hot enough to not only melt the intake manifold and wiring, and everything else plastic including the tanks on the radiator, but the friggin heads, and block were beginning to droop like......well use your imagination.
The 4.2 is pretty sound, IF you keep oil in it, and that cooling system is tight and right. They don't hold much coolant. Other than overheating or no oil, meaning lack of service, great engines compared to the 4.0.
Ok, but you still have a knock. When you say "can still lay rubber", sounds like you drive it hard, eh? Or no? Take it somewhere, have it checked out. Nobody can wave a wand at that noisy engine. And it sounds like that's what you expect. You repeated yourself with your second post, so I'll repeat myself, too. Without looking at it, which someone will need to do, it sounds like an engine failure to me. But again, just a guess over the net without listening to it. Could it be other stuff? Sure, and I mentioned those, too.
And you telling me there was a hose that let go, I would bet it overheated. You say you shut it off within seconds? Well I hate to tell you this, but EVERYONE says that very same thing when they blow their engine. Sure the hose failed, but no one really wants to admit that it was them who caused the meltdown, but 99% of the time, they keep on truckin'. Most don't pay enough attention to what the car is doing. And most of them always blame Jaguar.
Well the 4.2 in general is pretty tough. In the 7 years this engine has been out, I have had the pleasure of replacing only but a handful of these engines. All of them were from lack of maintenance or overheating. So my examples are similar to yours, even though you say you shut it off right away. I'll take your word for what you say, but you still have a knock and therefore should be diagnosed before real damage occurs. Who knows, it may be something minor!
Similar issue
Similar issue with my 2002 S-type 4.0.
I had a check engine light come on. A day later I started hearing knocking under acceleration. I took it into the dealer that day. They took 3 days to get back and said the believe the rod bearings are shot and that the car is 4 quarts low on oil. I had had it in for the 50K service late december and again later in december had the valve cover gaskets replaced due to an oil leak. At that time (12/30) they said no leaks, everything was fine. So how does the car go from that condition to 4 quarts low on oil in 6 months and less than 6000 miles? BTW - the temp looked fine, no noticable loss of power.
Have you had the knock fixed? What was the outcome of the knock? That'd be the more important issue, and what caused that.
Ultimately you are correct. By your description I should be checking the oil daily. I figured since the car was under the reccomended maintenance schedule and is a premium brand, i was doing fine. I've had cars where I knew to check oil regularly - my 65 mustang, my 82 toyota pickup. Even in the worst of times none of them lost 4 quarts of oil in 6 months. But I digress. Jaguar corporate said they will do nothing. 63K miles and the engine is dead (bad rod bearings according to the dealer) and they want $14,500 for a new engine. I'm not going to spend that money on a car that goes for 5-7000 at auction so I'm not sure where to go from here. I wonder if carmax will by it for parts. I love Jaguar styling and performance but this will be my first and last Jaguar. I appreciate your comments. BTW - I'm going to check my oil weekly on all my cars from now on.
Same problem
Man - I have the same problem with my '04 XJR. I started a couple of weeks back - slight loss of power at about 4500RPM and then it fgot gradually worse and a 'rattle' developed. It now loses power at a little over 3000RPM - To it to the Jag dealer - worth mentioning at this point there was no engine management light......They said it was a fuelling problem, and a software update foer the fuel management system should cure it - ran the update - no error codes stored......problem still there - I had recently fuelled the car so they suggested that it may be bad fuel and to reun it empty and then fill up somehwhere else as it was definately a detonation problem.....so....still the same problem - to it to a local garage and had the spark plugs done - now I have the engine management light and same problem - no error code tho??? Someone suggested it may be the CAM Sensors or a knock sensor......any thoughts?? If it was bad fuel, could it have wrecked the Llambda sensor? - did u get yours fixed BC04XJR ??
Cheers Guys
Cheers Guys
Wow - just taken the Jag round to a firend at another garage, and hey presto - fault codes - they seem to point to a problem with cylinder 3 on bank 2 - funnily enough - that's the one that had a slightly carbonised spark plug - seems like maybe a faulty injector???? - also mentioned about the pinking, and he suggested it may be something realted to a scondary throttle body sticking - so do I maybe have two problems here?
Aha - just an update- I got my problem fixed.....found this very knowledgeable guy......suggested it may be the CATS causing the pinking (rattle at higher revs). He says that in the XJR the CAT material is prone to melting!.....so - took the car to my local garage, who cut the cats along the seams, and removed the internal element, then re-welded the cats and put them back empty - car runs like a dream!!!!! - sounds like a bag of bolts tho lol, but that will all be sorted when the new cats go in. Hope that helps....
Samilcar (10-09-2020)
MC36
US Lower Atlantic
09-01-2015 07:34 PM
