XJR performance options
From what I hear on the STR forum the 1.5 lb pulley is great and a pretty easy mod with no cutting its just a pulley swop and the euro toys has no markings so no one will know you have changed it. As to exhausts Mina is cheap and well made but might be a bit tame. The STR has the same engine and tranny and they seem to mod more than the XJR boys do. I am going to look into the Mina exhaust but as I said the Spires would be the one I would want but at $2500+ it's a bit over the top for my 2004.
Hi kj217,
I'm looking at the same thing currently. I'm planning to start with a LSD as I get the impression that the stock diff is causing dampening of the off-the-line acceleration via the traction control system. I would expect it to make a fair difference.
It seems that most of the common upgrades (exhaust, pulleys, etc) don't make large power differences (I am restricting my opinion to those instances where people have proven improvements on a dyno). Hence, I am interested in a supercharger upgrade... although I see you would rather not touch the SC. I had a similar experience when modifying a Subaru with mild improvements with exhaust/cold air intake/tune then a monster improvement when I upgraded the turbo... ended up with around double my original power and torque!
Cameron just installed one of my intake pipes on his car with success. It was originally intended for the s type r but since the engines are the same, it fit. Check the last page of my thread.
https://www.jaguarforums.com/forum/s...-70750/page15/
Dickie_L_J_O
09-13-2015 07:44 AM
adam699
09-12-2015 05:32 PM
scottatl
09-04-2015 08:08 PM
