XJR vis XJ Super V8
Old 09-17-2009, 07:05 AM
Rich W's Avatar
Default XJR vis XJ Super V8
I'm looking at both and will do a face lift on either, 2009 style body color grill and boot tail cover with full length chrome strip trunk lip spoiler. Will also add backup camera from 2010 XF.
Other than the obvious, wheel base and a few amenities are there any major differences between the XJR vis XJ Super V8? It's a Little heaver but I'm more interested in performance (not much difference I bet) and handling.
Anyone actualy had a chance to 'ring out' both of them?
Old 09-17-2009, 04:09 PM
hlgeorge's Avatar
The Super V8 is a Vanden Plas with the supercharged engine. For handling, the XJR is the way to go, but most Jag owners are not going to use their cars on the track. The stiffer suspension and short wheelbase will suffer the ride quality. In the Super V8, the longer wheelbase and softer suspension will give you a more plush ride with similar performance.
Old 09-17-2009, 04:18 PM
wazari's Avatar
The biggest factor in handling of a passenger car is tires. I've driven both cars on the track but with different size tires and types it's difficult to compare. Since the XJR had 20's it definitely did handle better.
I have lowered my own XJR and that did increase handling performance without sacrifincing ride quality.
Old 09-18-2009, 01:00 AM
patrickw813's Avatar
I am one of those very awkward Jaguar owners that does take their car to the track...
You would not believe the feedback I get when people realize that my XJR is perfectly capable of holding it's own on a track, dragstrip, and mountain roads.
Is your car an X350? If so, how did you manage to lower the car? I do not want to spend thousands on the Arden piggyback system for the suspension....
Old 09-18-2009, 06:18 AM
StrateLoss's Avatar
ive seen the arden computers on ebay for $600 last week. maybe they are still around.
OP, id personally go with the super v8.
Old 09-18-2009, 11:17 AM
wazari's Avatar
Originally Posted by patrickw813
<snip>
Yes an '04 XJR would be a X350.
The procedure is relatively simple but needs to be done at a facility with a WDS and height measuring tools all dealers should have. You go the area in the WDS to calibrate ride height and add the amount you want the car lowered (within reason) to the actual measured height. This will trick the ECM/BCM into thinking the car is sitting too high and will readjust to what it thinks should be factory specs. I lowered my car about 1.25 inches all around. Only 1 hour labor.
Old 09-18-2009, 04:36 PM
Rich W's Avatar
Was there a noticeable effect on lowering the car? Any side effects? Wheel rub?
What about installing the XJR anti-roll bars (thicker) in a Super V8?
Old 09-18-2009, 05:05 PM
Charlienmr's Avatar
I drive an 06 SV8. Not much time behind the wheel of an XJR. Obviously, the SV8 has more rear seat room, which works well when you 16 yo son is 6'8". (2 M or so if you're metric). And SV8 has every option installed (except the dealer installed ones). Same engine, same brakes, suspension in between an XJ and an XJR, but does have CATS. I actually agree that the tires fitted will make the most difference in handling. And its kind of fun to blow most other cars away in a stretch limo.
Can't lose in my mind. Just try'em out and see what fits (especially if you have a very big rear seat passenger).
Old 09-18-2009, 06:02 PM
JgaXkr's Avatar
I have to ask how are you planning to add a 20210 XF back up camera to a Super 8 or an XJR??? Thet are totally different systems.
Old 09-18-2009, 06:24 PM
Yes how does the car look and feel? I would assume that the car feels more planted but since the dampening settings are the same, maybe there wasn't a marked difference? Your input would be greatly appreciated!
Would you kindly post some pictures? It would be great to see what a lowered X350 XJR looks like...
Old 09-19-2009, 07:24 PM
wazari's Avatar
No side effects, car feels better in turns. I don't of anyone that makes bars for the X350's
Old 09-19-2009, 11:35 PM
StrateLoss's Avatar
I think he meant swapping an XJR rsb into the SV8
Old 09-20-2009, 03:12 PM
cincinnati's Avatar
Wazari, can u post some pics of your car lowered please.
Old 09-20-2009, 04:07 PM
wazari's Avatar
Not a great picture but only one I had on file. I'll see if I can take some straight side shots later to give a better perspective
Old 09-20-2009, 04:44 PM
StrateLoss's Avatar
damn, i need those wheels.
Old 09-22-2009, 08:11 AM
57loboy's Avatar
Ummm - that pic looks an awful lot like the one Cinci has of his XJR that is listed in the for sale section. Link is here: https://www.jaguarforums.com/forum/s...ad.php?t=22315
Old 09-22-2009, 08:15 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Wow! Are you or the misses that tall too? Is he athletic?
Old 09-22-2009, 09:20 AM
wazari's Avatar
Yes my teen age son posted someone else picture rather than mine. I apologize, I have no idea why he did that. I do not have any pictures of my car right now but when I get it back from the body shop (rear ended) I will post some pictures. My car is black not gray.
Old 09-22-2009, 03:28 PM
Charlienmr's Avatar
I'm not that tall (6'1"). My wife isn;t either. However, many members of our families were in the 6'6" range and so my little guy is no eral surprise. Athletic? No. Mostly because he is averse to excessive effort (all formsof work really). Main thing is he didn't fit into the back of my car and so I had a good excuse to trade my 04 SWB XJ8 for the SV8.
Old 09-23-2009, 06:34 AM
carelm's Avatar
Hi Charlie,
A 16 year old son who's 6'8"? How many refrigerators do you have? My guess is a minimum of two. One for the son and one for the rest of the family.
Mike
Quick Reply: XJR vis XJ Super V8
