XJR (X350) Coolant Drain/Fill/Bleed R&I PDF
XJ (X350) Coolant Drain/Fill/Bleed R&I PDF
Forum member requested Instructions on removing 2005 XJR Supercharger.
One of the steps is Coolant Drain procedure.
Here is a PDF on the procedure (extracted from JTIS manual):
See post# 3 for the Radiator Splash Shield R&I.
Jim Lombardi
Jim Lombardi
Last edited by jimlombardi; 11-23-2012 at 07:28 PM. Reason: Added reference to post# 3
Hi
Update----- I found another thread that says the Radiator Splash Shield is held on with screws:
https://www.jaguarforums.com/forum/x...acement-70056/
Look at post# 1 - mentions "Mine is an early 04 build, so I had 16 screws to take out of the radiator splash shield. Later cars have a few less."
Here is also another thread on Draining Coolant Fluid on the X350 ( see post#2):
https://www.jaguarforums.com/forum/x...t-flush-34479/
Info before adding update:
The only other instruction needed appears to be the Radiator Splash Shield section (Removal & install).
Jim Lombardi
Jim Lombardi
Last edited by jimlombardi; 11-24-2012 at 10:02 AM. Reason: Deleted drilling out fasteners, Added removing screws
Block drain plug
The link above doesn't seem to work. There is lots of info on drain and fill using the drain plug on the bottom of the radiator, which I will do. But if I already have the big tray off the bottom of the engine (where you get to the oil filter) are there coolant drain plugs on the engine block? If you have any photos or illustrations that would be great so I know what I'm looking for. Thanks.
Jeff
Jeff
Staatsof
11-11-2010 03:17 PM
