ZF 6Hp26
Old 02-22-2019 | 09:22 AM
lesauto's Avatar
Default ZF 6Hp26
I have a completely rebuilt transmission we've been through it twice. It won't shift past third. Any idea's on what could be going on? When I tried to update the tcm I get this.
Old 02-22-2019 | 10:44 AM
motorcarman's Avatar
The ZF6HP26 was never fitted to the X308.
You might try the X350 forum section.
bob
The following 3 users liked this post by motorcarman:
AD2014 (02-27-2019), Don B (02-23-2019), lesauto (02-25-2019)
Old 02-22-2019 | 10:57 AM
lesauto's Avatar
I tried to delete the post when I realised I posted in the wrong place.
Old 02-22-2019 | 11:17 AM
lesauto's Avatar
Default ZF 6Hp26
We
Old 02-22-2019 | 11:54 AM
JagV8's Avatar
Exactly what car and also exactly which variant of the trans?
Did I mention to be exact...
The following 2 users liked this post by JagV8:
Old 02-22-2019 | 02:31 PM
lesauto's Avatar
I was trying to update the TCM to the latest calibration. It's a 2005 jaguar xj8 4.2 supercharged 6hp26m
Old 02-22-2019 | 05:47 PM
abonano's Avatar
Can't see the error message from your picture.
Are you using legit software? (What version of SDD?) For 2005 it should switch over to Legacy.
VCM or Mongoose - again, legit versions?
If your using pirated versions of either software or communication apparatus - proceed with extreme caution...
Finally, do you have the vehicle battery hooked up to at least a 30a - 50a charging unit before attempting any reflash?
SDD will not allow reflashing of any modules unless the battery is above a voltage threshold. (I believe it to be 13.0V)
A regular battery charger or maintainer will not cut it!
30a is the entry point, 50a+ is ideal.
The following 3 users liked this post by abonano:
Old 02-23-2019 | 09:40 AM
Highhorse's Avatar
Contact a Mod and ask them to move it for you. They are listed at the bottom right of each forum. Simply prompt one, go to their page and send them a personal message asking if they will move it for you....cheers.
The following 2 users liked this post by Highhorse:
Old 02-23-2019 | 06:49 PM
lesauto's Avatar
I'm use a Bosch passthrough device. I'm getting error code no calibration for this variant. I'm subscribed to topix with the latest version. I also have the battery maintainer on the battery.
Don B (02-23-2019)
Old 02-23-2019 | 09:36 PM
abonano's Avatar
What's the amperage on the maintainer?
Old 02-23-2019 | 11:14 PM
Don B's Avatar
Hi Les,
Welcome to the Jaguar Forums. It's great to have you with us. I replied to your thread in the X308 forum before realizing you had re-posted in the X350 forum so I have merged both threads.
A few questions come to mind:
1. Did your SDD package come with the additional calibration file library, and if so, is it properly installed? The package I use for programming 6HP26s is SDD Version 131.03 with the full calibration file library.
2. What VCI are you using? Mongoose clone, genuine Drew Technologies Mongoose, Ford VCM? The clones are not always reliable for control module programming.
3. Do you have a suitable power supply connected to the battery and the laptop plugged in to its power supply while attempting to program the TCM?
4. Did you clear the TCM adaptations prior to attempting to update the firmware?
5. What Diagnostic Trouble Codes (DTCs) are stored, in all categories including the Powertrain (P-prefix), Chassis (C-prefix) and Network (U-prefix) codes? Some DTCs will cause the transmission to be locked in 3rd gear and Limp Home Mode.
6. During your rebuild did you swap in a Mechatronic (Valve Body/TCM) from another type of vehicle, such as a BMW, Ford, Hyundai, etc.? If so, JLR SDD may not be able to update the firmware.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (02-27-2019), rsa760041 (10-18-2021)
Old 02-24-2019 | 10:04 AM
lesauto's Avatar
We reused the TCM and I'm running the latest version of SDD and I use a Bosch vci passthrough. I have a battery maintainer just for flashing. I was able to clear flight recorder data with it but it won't let me update the tcm in normal mode or coded. I have flashed a lot of vechiles but this is my first Jaguar. I'm getting a gear load code. I believe it was p0783.
Old 02-24-2019 | 12:56 PM
abonano's Avatar
I think your Bosch vci pass through device may be the issue. Latest version of SDD is non relevant as the latest TCM version for this vehicle was rolled out with version 131 or so... the gear load code might be a road block also but my money is on the Bosch unit.
Don B (02-24-2019)
Old 02-24-2019 | 01:16 PM
Don B's Avatar
Hi Les,
P0783 will definitely trigger Limp Home Mode, locking the transmission in 3rd gear. Here is the definition and list of possible causes from the DTC Summaries manual:
You can download one of the more complete Diagnostic Trouble Codes Summaries versions here:
X350 DTC Summaries
Assuming your transmission does not have an internal mechanical fault, you might look into the torque signal to the ECM, which begins with the Mass Airflow Sensor. Do you have any DTCs related to the MAFS or CAN (U-prefix codes)? It would help us if you could list all of the DTCs stored in the car, regardless of how unrelated you may think they may be.
Cheers,
Don
The following 3 users liked this post by Don B:
AD2014 (02-27-2019), Highhorse (02-24-2019), lesauto (02-25-2019)
Old 02-25-2019 | 08:53 AM
lesauto's Avatar
I had a O2 code replaced the O2 sensor cleared all codes reset adaptive shift stratiges and still the same problem. The valve body has all new solinods and a zip kit in it. I'm thinking it could be a bad tcm. I can find BMW and Ford TCM'S but not a Jaguar TCM.
Old 02-25-2019 | 10:27 AM
abonano's Avatar
If you think it's the TCM I have one available removed from a 05 XJ8. They usually don't go bad and it will need to be re-programmed.
Old 02-25-2019 | 10:32 AM
Don B's Avatar
Hi Les,
As the DTC Summaries guide I linked you to attests, O2 codes can be caused by many issues besides a failed O2 sensor, which is now obviously the case with your Jag.
Without giving us the full picture, you're asking us to offer wild guesses. Issues like yours are often complicated and require a full overview to diagnose.
Please post ALL of the DTCs stored in the car, including the P-, B-, C- and U- codes, and please share with us all of the symptoms that led you down this road of rebuilding the transmission, including all symptoms that did not seem to be directly related to the transmission.
Cheers,
Don
AD2014 (02-27-2019), lesauto (02-25-2019)
Old 02-25-2019 | 02:19 PM
lesauto's Avatar
When I get back to this car I will update everyone. Thanks for all of your help. I had to move on to something else this car is driving me crazy.
Old 02-25-2019 | 03:11 PM
lesauto's Avatar
How much for the tcm?
Old 02-25-2019 | 04:12 PM
abonano's Avatar
PM me
Quick Reply: ZF 6Hp26
