1995 Jaguar XJ6
Crank shaft sensor gap between sensor crankshaft on mine was greater than .047 adjusted spacing to .025 solved my issue with ckps .
Even bought a new sensor didn't help till i adjusted spacing.. Also had other issues. O2 sensors and ground on left driver compartment by left foot door wall. It has a painted surface . Took a wire brush on drill motor to take it off. Upper and lower brake lite didn't work. Still tracing circuit through car to lights. Drained tank and put new gas in tank. Today car ran for 20 min no misfires. But o2 sensors is out waiting till fri for sensor. Iscv coming next week. Check your throttle position sensor under carb. Center wire with key on volt meter should be between .1v closed throttle to 4.9 wide open throttle. No engine running turn throttle by hand to full throttle slowly and see if a smooth all the way to wot.
rusty37
06-07-2016 04:43 PM
