1995 Jaguar XJ6 Warning lights on don't know why?
Recently, I parked my XJ6 in the airport in sport mode, six days later I came back and saw that my traction warning light and brake light are on in the instrument panel. I rarely use sport mode, so could this trigger the problem? we did a battery reset and the lights are still on. any ideas? thanks so much
Welcome to the forum. There is not much chance of sport mode causing the error. Are you referring to the ant lock warning light? It could be a dirty sensor, broken connecting wire or a fault in the ABS module. Without the relevant codes, it's hard to tell. Unfortunately, generic code readers cannot report brake system codes, and you will probably have to visit a specialist or, last resort, dealer to get the codes.
Are you able to do your own maintenance and repairs?
Thanks so much
Again, if it goes away, it was probably just the battery voltage. If not, it is likely the motor power circuit connector on the ABS module, or a dodgy wheel sensor. Tyr restting the ABS module by disconnecting a battery lead, wait a few seconds, then reconnect. Start the car. If the light comes on immediately,it MIGHT be the motor circuit. If the light comes on after you are moving, it MIGHT be a wheel circuit. The best way to remove the "MIGHTS" in the explanation is to read the ABS module code, but a standard OBD scanner will not read them- that takes a dealer level software with Jaguar specific code capability.
I don't have traction control, but when I had the ABS motor-circuit issue, the ABS light was always off on startup and illuminated after 100 yards or so of driving; generally same spot in front of my neighbor's house.
As to concern, I can't think of a fault that you'd exacerbate system damage by driving it - just beware that as long as you have the lights you don't have the systems - so steer clear of situations where you need anti-lock brakes and/or traction control.
It may have, Ross....I haven't experienced a wheel sensor issue yet...only the motor circuit...and for several weeks (before I got Bob to read the codes and confirm what it was) was always hopeful of a blank panel all the way to the end of the County Road (about 1/4 mi) but of course it never was to be. So I have less to remember :-)
Worse still, after my first attempt at repairing it....cruising in front of neighbor's all confident and smug...and bam! ABS light! Fortunately, I wasn't THAT confident before the check-ride and only taped it back together!
I thought maybe they ran a different BIT-check if you also have traction control or something?
Well, according the the aholbro, it could still be the motor connector. Look in the archives about that- the ABS pump motor plugs into the module with a two prong plug and the solder connections come loose. There are folks that fix them for less than $100., or you can saw the module apart and solder the connector yourself, or you can drill two holes in the case and do it that way, simply taping over your drill holes with some high quality sealing tape of some sort. Again, much is in the archives. I advise getting the manufacturer specific codes read by someone before tearing into it.
I want to mention that on the Traction Control Actuator(MNA5930AA), at least on the X300, the two wire's insulation on the unit just crumbles eventually and the wires short out. I have seen this happen to several. On my own the ABS and Traction Warning lights went on. Eventually I found that the wires on bottom of the unit had shorted, but the upper end looked good. Some I have seen are bad at the top and bottom. It may be due to UV since the insulation under the black wire tube seems to be ok. I have not disassembled the unit to rewire it. I hope that the shorting did not permanently hurt something. I have not seen this problem mentioned and wanted to bring it to someones attention. Anyone with an X300 and traction control should be aware of this problem.
The following 2 users liked this post by WhiteXJ6-96:
BigBossRadio (04-05-2014),
sparkenzap (03-20-2014)
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
