1995 xj6
There is a bearing in the center differential housing that the left and right short output shaft involve
Common on the X300
https://parts.jaguarlandroverclassic.../brand/jaguar/
Common on the X300
Thomas Freeman (08-20-2019)
Welcome to the forums Thomas,
I see you followed Grant Francis' advice about a re-post so I've deleted your original from XJ6 & XJ12 Series I, II & III forum.
Received 2,195 Likes
Dont be so fast to condemn the side you "think" you hear it from. Reason i say this is because on mine i recently had a roar i know is a wheel bearing and would place money on right rear. But being a tech i put on lift, ran in gear and listened with mechanic stethoscope. I'll be damn rr totally quiet, it was left rear. So put on jack stands and use a stethoscope to listen. You'll be amazed at the accuracy of listening to the differing sounds from each area checked. Best of all theyre cheap at sears or harbour freight
The following 2 users liked this post by Brutal:
aholbro1 (08-22-2019),
motorcarman (08-21-2019)
