1995 xj6 drivers door handle cable
It is the same size (for the front doors, LWB changes everything). Most of the car parts web sites have got them. Thepartsbin.com I believe has them for $150 or so which is a bit too much. You can also try eBay, or some other salvage yards. Of course, there are some do it yourself variants which are loads cheaper, like $5.
I did a replacement all myself. Below are the instructions.
If you don't follow then please ask.
Good luck.
my advice is to anyone is to remove the door panels and spray the lock mechanisms thoroughly.
Now to the cable replacement. Remove the snapped cable.
I bought a new generic metal cable from a hardware store and
inserted one end into one of those small electrical cable jointing blocks you can buy and
screwed down firmly onto the metal cable. Insert the other
end into the cable cover until it emerges at the other end.
At the lock end, what was once the original cable stop (now the new electric cable block) is hooked into a slot in the lock mechanism. I had to use a mirror inside the door to
see what I was doing!
At the handle end thread another electrical block on to the
cable and insert the cable end into the small round green
plastic tube which is at the handle hinge. Put it in from
the top and bring it out from the bottom and pull it fairly
tightly and place the end through the cable block which
already has the cable inside it. Tighten down with the
screws onto the two pieces of cables (one the whole cable,
the other the folded over end).
Hope this makes sense. If not ask!
Don't know if you've stripped it down yet, but as with all jobs when you
have the thing in front of you it makes more sense!
Good luck.
They are widely available everywhere I think. See photos.
For the job choose a fairly small type, cut away the plastic covering and just use the metal part which houses the small screws.
Guest
Posts: n/a
Do you (or anyone) still have a cable for an interior driver's side door handle? I could use one.
windsheild wiper reservoir
I have two 1996 Jaguar xj6 and they both had leaks in the wiper reservoir. If all you have is a big crack or whole (one of mine had a big hole) you can patch it up with some stuff I forgot what it is called, but you can buy it at pepboys or autozone. it works great. I had a really big hole. I had to put several layers on it but it worked. Reservoirs I understand can be hard to find and expensive ($85). Good luck.
You have posted this in a three year old thread about door handle cables....?
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
