1995 XJ6 rear jack points
Old 02-28-2016, 09:33 AM
superA's Avatar
Default 1995 XJ6 rear jack points
So I am getting ready to change out my fuel filter and am wondering where the correct jack points for the rear of the vehicle are located, using a 2 ton floor jack. I have tried google but am getting different information. As heavy as these cars are I want to be correct and safe. Thanks.
Old 02-28-2016, 12:18 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
The jack points are square tubes, the back one about 6" forward of the wheel well opening. The factory jack slides into the tube.
superA (02-28-2016)
Old 02-28-2016, 01:28 PM
superA's Avatar
Car didn't come with a factory jack. Will putting a jack under that tube work?
Old 02-28-2016, 02:19 PM
RJ237's Avatar
Yes, that's what I do.
superA (02-28-2016)
Old 02-28-2016, 02:27 PM
superA's Avatar
Thanks. This may sound dumb, but any issues with putting the jack stands under the same bar?
Old 02-28-2016, 04:08 PM
Scarecrow's Avatar
Nope, you're fine. I do it all the time.
superA (02-28-2016)
Old 02-28-2016, 07:56 PM
Received 8,075 Likes on 4,870 Posts
You might want to lift the entire rear of the car centered under the diff area and use the square tube jack points for the stands.
Just use a block of wood on the floor jack so you wont bend or damage suspension components.
bob gauff
superA (02-28-2016)
Old 02-28-2016, 08:34 PM
superA's Avatar
I ended up just getting the fuel filter off without it jacked up. Such a low to the ground heavy car, makes me nervous tinkering around with stuff so close to the jack stands.
fireman-175
02-29-2016 09:05 PM
harvest14
02-18-2016 01:52 AM
Amelorn
24
02-11-2016 01:58 PM
Jennifer S Flavell
02-04-2016 05:13 AM
Softball60
01-31-2016 01:51 PM
Quick Reply: 1995 XJ6 rear jack points
