1995 XJ6 rear view mirror removal
Guest
Posts: n/a
I bought an oem replacement rear view mirror for my wife's '95 XJ6, and I need to know how to remove the old one. There was apparently a vin# break in this model year for the mirror - mine is the round button type with a white connector. I have searched and searched and been unable to find removal instructions for this particular mirror, and I don't want to break anything in the process! Thanks.
Not sure, this is the X Type forum try the XJ forum if this doesnt help.
Not sure if this is re the mirror you mean but it is for a 95 XJ(6?) 4.0
SRO 76.10.51
Disconnect vehicle battery ground lead.
Rotate mirror stem approximately one quarter turn clockwise to release stem from spring contact on windscreen boss.
Disconnect mirror harness.
To refit, locate mirror stem base on windscreen boss with stem parallel to top of windscreen, ie one quarter turn displaced from normal position; apply firmly over boss and turn anti-clockwise to lock stem on windscreen boss.
Refit in the reverse order of the removal procedure.
davidladewig
09-03-2015 06:32 PM
