1995 XJ6 suddenly rough at first cold snap
My 1995 XJ6 has a lot of miles on it, but has been taken care of well over its lifetime (I am 2nd owner). This is my first winter with it and suddenly on the first really cold day (10 degrees F) it is running roughly, like it's missing.
I put a bottle of fuel injector cleaner in with the last fill up, but I'm not certain that helped.
I have never owned a car with coil packs. Is it common that cold weather will cause a coil pack to loosen?
Is it any trouble to reseat the coil packs, or does this involve installing new gaskets?
What else might I check?
Thanks, RJ237, for the suggestion.
I did as you said and did not see any arcing.
I would like to remove the coil pack wiring harnesses one at a time to see if there's a particular cylinder not firing.
Two questions:
1. How do you get the wiring harness off? Some gentle prying with a screwdriver (even two screwdrivers, one to lift the clip) didn't seem to do it.
2. Can I do this without shutting the engine off each time (will I get shocked)?
Thanks again for your help.
Two questions:
rusty37
04-05-2020 07:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
