1995 XJ6 Wont Turn Over and door locks don't work! Fuel issue? Security issue? Module
Hello everyone and how are you. I have a 1995 XJ6 in almost perfect shape for 100k miles. At this point, here is the current condition / issues:
- Key turns on... gauges power up... but motor does not turn over. I do hear a relay clicking in the trunk when I try to start it... but don't hear any other relays clicking when I turn the key
- I don't hear a fuel pump firing up like you normally would when the car is powered.
- None of the door locks work. I don't have a key fob, but when I use the key in the door nothing works... when I manually lock and unlock from inside the car, nothing works. Centralized locking button on the console does not work or light up.
- Rear trunk button does not work... and cannot hear relay working.
What have I done so far to fix it?
- I have replaced ALL of the square "blue" relays within the car...
- I have replaced the larger black relays right behind both drivers and passengers side headlights for the; Starter motor solenoid (drivers side), Engine Management system control relay (pass side)
- Red P and N light up red on the gear shift... wiggled it while trying to start it... no difference
- Took drivers side door panel off to inspect and everything looks normal.
- I did "jump" the starter from the single wire between the fuel rail and the valve cover... starter works fine and I have solid power running to the positive power pole running through the passengers side firewall by the motor.
- Charged the battery to ensure proper voltage
- Inspected wiring behind the rear seat from within the truck... looks normal
- Inspected the inertia switch... it's working and reset
At this point the only relays I have yet to replace are the "purple striped" relays for the Fuel filler flap, drivers/pass door lock, and two of them for the gear shift lock out. What could be the problem here?? Is there a module that could be faulty? Any further tests that I can run? Curious as to where the power runs to the door locking system... maybe I can trace it back up the line? Maybe the car was locked (security enabled) then door lock relays went out so it is not in a permanent state of security activation?
Any help is much appreciated.
I am thinking that I should probably focus on the door locks and starter circuits... I found the below on the net about the fuel pump system:
"There are three main components to the system: the trunk-mounted, constant pressure electric fuel pump, a control relay, and a voltage directing diode pack. The system is so designed that the pump will operate when the starter motor is engaged and when the motor is actually running."
So it sounds like the fuel system does not activate until the starter is actually engaged, which mine is not.... so fuel system could be ok. Any thoughts on where to go next here?
No.... just went to start the car one day and did nothing.... really just stopped working for no reason.
**Quick Update** I replaced the "Body Processor Module" and fixed SOME of the issues. Now, the lights turn on... fuel pump works!... and Car fires right up!!!... I also found out that the alternator was bad so I replaced it with a new one. It is showing a constant 12.5 volts and goes as high as 13volts when driving.
Now onto some other mysteries... the door locks still don't work (nore does the central locking system button) and the car often continues to run after I pull the keys out... BUT... when I shut the door, the car shuts off??? WTF??? Almost like it is in some sort of Valet mode but when I press the valet button on the console nothing happens. Any thoughts?
Brad Carr (08-23-2016)
JimC64
10-13-2015 07:08 PM
