1996 4.0l 6 cylinder jaguar vanden plas right heel fusebox
Hello.
I need some help please. I have the electrical wiring diagrams for my 1996 jaguar, but I am unable to find any information on 4 fuses in my right heel fusebox.
The fuses in question are fuse numbers 16,14,12 and 10.
The Sedan Range 1996 Fig 01.2 "Battery Power Distribution - Heel Board Fuse Boxes" does not show these in use however there are fuses at this location with wiring attached.
I pulled open the fuse panel to attempt to trace these down but stopped. Here is what i have found so far:
PLug A CA36 pin 5 color coded wire WRR goes to fuse #16
Plug A CA36 pin 8 color coded wire WSS goes to fuse #14
Plug B CA44 pin 10 color coded wire WPP goes to fuse #12
Plug B CA44 pin 7 color coded wire WKK goes to fuse #10
These wires are hot with the ignition switch in the run position but I have no idea what they are for. Does anyone no??
Thank you.
Richard
Thank you.
Richard
Fuse 10 , 12 , 14 , and 16 rely on the relay in the corner ( ignition positive relay position # 4 on page 18 ) of the fuse box to be closed by the ignition switch providing the relay with a control half ground , this wound be a control command , the 2nd half being the power contacts half
This would then provide power to fuse 10 , 12 , 14 , 16
The other fuses 1 - 9 and on bypass the relay and would be hot at all times
Fuse chart coming and on page 21
www.jagrepair.com/images/AutoRepairPhotos/X300 1996 LWB.pdf
You have the option of swapping the Left engine bay relay # 7 because in reality it only runs the horn
With the ignition switch in the run position ( engine not started you can remove the relay on the right heelboard fuse box and feel it click back open
The relay can click sayng it is getting the correct command but still have bad power contact points inside
Newtothis2 (12-14-2021)
Hello.
10: Serial communication and fuel pump relay
12: Air conditioning module, seat memory
14: lighting control modules
16: windshield washers, climate control
Parker 7 (12-13-2021)
Newtothis2
11-18-2021 01:03 PM
