1996 Jaguar x300 (3.2 left handle type) Auto door lock not working
트렁크를 포함한 모든 도어는 리모컨으로 열 수 없습니다.
차량 내부의 트렁크 스위치와 센터 콘솔의 잠금 버튼도 작동하지 않습니다.
slcm/보안퓨즈/드라이버 와이어 도어 액추에이터를 모두 확인하고 리모콘 건전지도 교체했는데 신호가 나오지 않습니다.
Reader / Exciter ecu만 확인할 수 없습니다. ECU가 어디에 있는지 찾을 수 없습니다. 찾을 수 없습니다.
ECU가 없는 모델이 있습니까?
All doors, including the trunk, cannot be opened with the remote control.
The trunk switch inside the car and the lock button on the center console also do not work.
I checked all the SLCM/security fuse/driver wire door actuators and also replaced the remote control battery, but there is no signal.
Only the Reader / Exciter ecu cannot be checked. I can't find where the ECU is. Not found.
Are there any models without an ECU?
I would ask "does the car lock and unlock manually, each door and trunk, using only the key?"
I'm not intimately familiar with the x300, but can you perform an "all doors lock" using the key? I'd ask if that is working as well...withOUT using the FOB.
I would start by unplugging and replugging back in the door lock relay, IF the x300 has one similar to the XJS. The XJS uses DAC4862 and is problematic on both my 96 cars. Unplugging it and plugging it back in always restores it.
If not, the Security ECU (which I know the x300 does have) might be damaged? I haven't read about that being a common problem though.
Lastly, the remote locking feature getting wonky is usually indicative of a failing battery for the XJS I have owned. How old is the battery?
