1996 Jaguar XJ6 -- wont start
yep, i'm agree with spark, same thing happen to me, the hose blew off fuel pump,and for me was an all day job, too take tank out, and while i was there i replace fuel pump had 179k, i think what might of cause it to blow off was the fuel filter over the, slowly clogging up, i looked thru all my records never could find that it was changed, fairly easy to do
Geno
1995 xj6 186k
Geno
1995 xj6 186k
Start with the basics, car needs fuel and spark to run.
To check spark,
Just spray some carb cleaner into the intake and see if the engine will fire. If it does, then you're getting spark.
To check if you're getting fuel
Make sure that you're getting fuel to the injectors by disconnecting one of the lines and directing it to a container. The see if you're getting fuel.
If you are, remove one of the injectors, and see if it's getting triggered.
If you're still getting fuel then your injectors are firing so you need to check spark. If not then you can check if you have a bad fuel pump relay or fuel pump.
Good luck.
To check spark,
Good luck.
1964Daimler
09-02-2015 11:41 PM
Terrance Williams
08-26-2015 11:50 AM
