1996 X300 Glove Box
1996 X300 Glove Box
Hello, I was trying to program keyless entry fob and something has dropped down from behind the glove box, it's a plastic oblong thing not solid with holes about a half inch thick but I guess the same dimensions as the glove box. Has the BCU moved it? How do I fix it back behind the glove box? Thank you
The BPM back there is mounted in a metal sliding carrier where the module would slide down after removing a plastic plug / pin
This pic from someone shows BPM slide down from the meter carrier , no need in your case to remove center console
The trick to glove box removal is to keep track of the fasteners and position and elongated hardware holes position on a cardboard with holes punched in it
See this glovebox parts breakdown
Search Genuine Glovebox Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
4 holes on the slid down part ?
See this thread with pics of what goes on and here again the BPM is slid down out of carrier
Glovebox retrofit. - Jaguar Forums - Jaguar Enthusiasts Forum
" So I need to a simulated piece of cardboard to note fasteners? "
Yes , just a flat peice
the last pic is some climate control air duct with foam on the sealing edge
May not need to remove glove box but swing yourself upside down under the passenger dash
pic coming
pic coming
MrNige2 (09-20-2024)
See the 4 pics / sections in this parts pics
Search Genuine Air Distribution/ducting Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
And maybe a better picture on page X of this Jaguar 701 PDF doc
T701 TITLE (jagrepair.com)
sws805
12-14-2012 09:36 PM
