1996 X300 Humming/Buzzing Noise, please help
I was also going to mentioned hub/bearing. My Jeep is starting to make the similar humming. If it is a bearing/hub, don't let it go for too long as it will get dangerously worse, as in wheel falling off. Labor is a pain on it unless you rent the tool yourself. I've done it before, not terribly hard. You can hear the noise at lower speeds, but it should get noticeably louder when you go highway speeds if the bearing is truly the issue.
indeed. but they are cheep & locally available usually at O'reillys or autozone,
the only special tools you'll need are a set of race drivers, (replace the races while you're in there!!)
and a bearing packer.
pretty much like doing wheel bearings on any RWD ford, minus the fact that the rotors aren't hubbed, jaguar's have the rotor & hub separate.
baskervillema
10-01-2015 06:43 PM
[WTB] X300 Canadian BPM
280zx-turbo
09-28-2015 04:37 AM
