1996 x300 sovereign starting probs
Guest
Posts: n/a
Hi
Every now and then i have starting problem, the engine cranks over but no fuel pump or spark. If i lock and unlock the vehicle several times the engine will go, if i keep it unlocked it will keep starting as soon as i lock it the same problem, could this be that the coded signal from the locking module to the engine module to inhibit start is faulty?
