1996 XJ^ VDP AC Expansion valve
RE: 1996 XJ^ VDP AC Expansion valve
opastu
Expansion valve is unfortuntly part of the evaporator core
you'll need to replace complete evap core which involves removing entire dash to start with
not something i"d advise a novice/beginner in doing:-(
describe why you think the expansion valve is bad?
Guest
Posts: n/a
The problem I have is that the compressor shuts itself down very shortly after activating. There is a full charge of freon. Periodically, the compressor will stay on a bit longer, perhaps for several minutes, then it shuts down. A local mechanic thought it might be the expansion valve. Could it be something else...perhaps less complicated that ripping the dash apart?
Thanks,
Stu
Thanks,
Stu
I suggest replacing the relay for the compressor clutch to start with, just to be sure it isn't giving up. The next place to look is the pressure switch, if it is going bad, itmay trip off the clutch. I would makethe expansion vavle the last thing to check, which will require tools to check.
aholbro1
08-05-2021 05:02 AM
WTB[NorthEast]: 1996 Vanden Plas Rims
kevinl
09-18-2015 11:00 AM
