1996 XJ 6 - Radiator fans always on?
Hi everyone,
Can any tech savvy guru fill me in? Should cooling fans (Facing radiator) be always onmy 1996 jaguar XJ6?
Mine are on, even when I start the vehicle and remain on ....
Dealer says NO, another reputable mechanic place that checked the "bulletin" - says Yes.
Kind thanks,
Mike
Kind thanks,
Mike
Received 10,873 Likes
RE: 1996 XJ 6 - Radiator fans always on?
I always get mixed up on this but I believe yours is "original" operation which was later changed by a different wiring to the a/c pressure switch...or something along that line....to prevent it from running at all times.
I'll try to find the info if nobody chimes in with a concrete answer
