1996 XJ6 fuel blockage
Hi guys im hoping someone will be able to help me.
I have a 1996 XJ6 3.2 ive been doing work on it as i got it as a non runner. Its started fine but i turned it off last night now it wont start at all!! Its turning over but just not firing, im suspecting a fuel blockage or something.
If anyone could have some idea what i could try it be much apritated
Kind regards
Dave
Kind regards
Dave
hi,
your car is a X300, not the Series 1, 2, or 3 XJ-6.
you might post to the X300 forum for more experienced help, but you could have a bad Cold Start Injector, Fuel Pump, Fuel Pump Relay, or Fuel Regulator. Best to check with those who have the same car. At least the engine is turning so it should be easy to repair.
I've moved your question from XJ6 & XJ12 Series I, II & III to X300 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Received 13,425 Likes
Welcome to the forum. Sorry to hear about your issues, but usually a no-start is caused by something simple, especially after the car has been running fine.
Two of the most common causes are a weak battery or a failing crankshaft position sensor.
If the battery voltage drops to between 10V and 11V while cranking, the Engine Control Module will not trigger the ignition, and your car will not start even though it cranks and cranks. The battery may measure well under no load, but its power delivery may be insufficient to satisfy the ECM. Jags need a strong, healthy battery.
If, while cranking, the tachometer shows 0 rpm, the most common cause is a failing crankshaft position sensor (CKPS), which is mounted on the front of the engine to sense the teeth in a reluctor ring on the crankshaft. The ECM uses the CKPS signal to adjust ignition timing, so if the CKPS signal is missing or implausible, the ECM will not start the engine.
If you have a decent voltage/ohmmeter you can check the battery to see if its voltage is sagging while cranking the engine.
The tachometer test is easy - just watch to see if the tach reads about 200-250 rpm while cranking. If it reads 0, replace your CKPS. All Jag parts specialists carry the CKPS, but most local auto parts stores such as O'Reilly can get one for you within a day. I carry a spare CKPS in the trunk of our '93 because it is such a common failure point.
Please let us know if all seems well with the tach and battery tests and we'll move on from there.
Cheers,
Don
Hi Dave,
I'm sorry for your continued no-start. I would recommend disconnecting the fuel line at the inlet to the fuel rail (on top of the engine closest to the firewall), holding a suitable container at the fuel line to catch fuel, then cranking the starter to ensure that fuel is flowing from the fuel line. If not, there is a problem with the fuel pump circuit (not necessarily the fuel pump itself).
If fuel is being delivered to the fuel rail, reconnect the fuel line to the rail, then pull one ignition coil and remove the spark plug from that cylinder. Insert the plug into the coil and position the plug so that its ground electrode is near a metal part of the engine so it will be grounded. Crank the engine and confirm the presence and color of the spark. If you have no spark then that will help with the further diagnostics.
I don't think your symptoms suggest a problem with the Park-Neutral switch in the J-gate gear selector assembly (I don't think the engine will typically crank at all if it's a P-N switch problem), but it might be worth wiggling the gear lever to ensure it is fully seated in Park, and also trying to start the car in Neutral.
And forgive me for asking such an obvious question, but is there a decent quantity of fresh gasoline in the fuel tank?
Cheers,
Don
rusty37
04-05-2020 07:40 PM
