1996 xj6 stall no start intermittent issue
hey there, we have a 1996 xj6 that has a intermittent stall/ no start sympton it happens every time you run the car its just a matter of when and where. We have recently replace the crank sensor and the MAF sensor and still no dice. The car has great fuel pressure and consistancy. Its as if the engine dies electrically (the rest of the car lights dash lights are fine, there is no codes in the ecu) any help is greatly appreciated.
phil
olde english garage, burlingame, ca, 94010
phil
RE: 1996 xj6 stall no start intermittent issue
have had several times... either fuel pump internal hose is half on.. or ecm connector corrodes fuel pump relay pin.. or ecu full of water.. also had ecm relay.. intermittent.. had one car.. stall once every 2 days.. took some time but i found it.. hope this helps
In that position my car has only one relay: the black one for horn. Anyway I probably found the origin of my problem; it was for a supplementary relay installed on the fuel pump relay circuit related to an old alarm system . This relay probably blocked the fuel pump with an alarm signal, now I will replace the original connections an test if it's all ok.
1964Daimler
09-02-2015 11:41 PM
