1996 xj6 sunroof won't close
Hi Emerson,
1. Try to spray some lubricant on the runners to see if that helps. You're right in that it may be jammed.
2. Go to the General issues forum and download the JTIS manual from Christo's message. Kind of long, and the manual covers only 1998-2003 XJs but for sunroof issues you should be OK.
3. If it's an emergency, you can manually close the sunroof by removing the overhead garage door and sunglass panel. The sunroof motor can be turned by a screwdriver if I remember correctly. The procedure is outlined in either the owners or maintenance manuals.
4. Cover the opening with acetate and 100 mph tape until you can get it fixed
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Guest
Posts: n/a
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I have the exact same problem. travels approx 3 inches and slows to a stop. Tried closing it manuall with screwdriver into base of motor but cant get past the same spot! Opens fully manually but again can only move it 3 inches manually. Have lubricated it well also. Any ideas? Going to rain for the next 3 or 4 days. :-(
John
John
When you get it closed, lift it with the tilt function, slide out the headliner cover, and remove the roof panel portion. From there, you should be able to better diagnose the issue. Of course, if you do get it closed, I really suggest keeping it closed, and forgetting you even have a sunroof.
One of the cheap plastic tilt function pieces broke on mine, and I had loads of issues with it closing and sitting properly on the frame. Right now, it's shut, and I've got the $200 replacement piece in my closet waiting to have enough money/motivation to tackle it myself, or call my mechanic.
99xk8guy
06-05-2023 06:28 AM
