1996 xj6 supercharger?
Old 06-07-2012 | 08:11 PM
AlbBolivar's Avatar
Default 1996 xj6 supercharger?
Would a super charger from an x300 xjr fit an x300 xj6? Would modifications have to be made of any kind?
I'm curious because I see some for sale on eBay and other places for pretty cheap and it would be pretty cool to be able to just "bolt" it onto my AJ6 engine.
Old 06-07-2012 | 08:40 PM
Doug's Avatar
If there's a will there's a way but you'd be much better off buying a supercharged car. The list of differences between the standard engine and the supercharged engine is pretty long.
Old 06-07-2012 | 08:41 PM
Vector's Avatar
If it sounds too good to be true, it probably isn't..........
I don't think it will work without a wiring harness, ECU, and several other parts from an XJR. That is how it works on a 308, YMMMV.
You are better off to sell your car and buy a real XJR if you want the power upgrade.
Vector
Old 06-07-2012 | 10:17 PM
AlbBolivar's Avatar
Thanks for the replies. I didn't really look into it deeply and figured I'd ask the question to those that already knew that answer instead of wasting my time looking around.
It makes sense that harnesses and the ECU would play a factor into it.
Old 06-07-2012 | 10:28 PM
Doug's Avatar
That's just scratching the surface :-) The supercharged engines had a different block, head, and pistons, MAF, ECU, injectors, etc. Different radiator and cooling plumbing, plus the addition of the intercooler radiator and electric pump. Different transmission, axle ratio, suspension.
Old 06-07-2012 | 10:51 PM
AlbBolivar's Avatar
Aww man, and to think, they look so much alike on the outside.
I was hoping they'd fit since on eBay they're pretty cheap and thought it'd be a great way to add some horsepower and have an "xjr".
Life isn't easy.
mrplow58
01-21-2024 06:53 AM
rusty37
04-05-2020 08:40 PM
Ozzy_UK
45
02-19-2019 03:05 PM
Terry007
09-24-2015 11:36 AM
SouthernGypsy
09-03-2015 11:54 AM
Quick Reply: 1996 xj6 supercharger?
