1996 XJR Emissions fail
Mr Darcy
Milady,
do you know what value the thermistor is? This is the little orange semiconductor with a yellow band attached to two of the four wires at the bottom of sensor, right?
There should be a source on the thermister inside as a DIY without buying the whole unit . Just have to drill out the pop rivets and a common screw to go back together . I realize there is a supporting circuit board . There was a class action lawsuit against Volkswagen about this . I have a way to calibrate a thermister ( plus a ELM327 ) as I get around to it to see if one from a source works . I'm a really cheap guy . My MAF reads in the past . Lucas 20AM series = ( ? ) LNA 16200AA supercharged , LNE 1620AA ( Lucas 70390B ) N/A
Received 13,290 Likes
Welcome to the Jaguar Forums! It's great to have you with us.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
MountainMan (05-17-2020)
