1997 jaguar xjr v6 supercharged...problems
Ok i recently bought this car from a guy that couldnt find out the problem with the car an gave up it was a good deal so i took it. car interior is perfect an the outside is in good shape jus a paint job. drove fine for the first couple days then the tranny light came on then it went into a bucking mode so i turned the car off then back on an the light went off drove fine next day same problem i put the car in neutral turned the car off then back on the light went off then i put it into gear an it drove fine again. so after that a couple months went pass an it would go back into bucking mode a few times then one day the check engine light came on so i hooked it up to a reader and 4 codes appeared (p1775 manfac tran control) (p0730 gear ratio incorrect) (p0139 02 sensor)and (p0122 pedal positioning sensor) so i dont know where to begin can anyone steer me in the right direction thanks
The following 3 users liked this post by sparkenzap:
Im tryna get help on a vehicle not goto english class so if you have any advice that would help please let me know other then that keep your bullshit to yourself an if your are really tryna help me but cannot understand what I wrote please let me know other then that thanks for the reply but it it not meant to help me out then keep it to yourself thanks
labcoatguy (09-23-2015)
If you wish to remain here then take the suggestion on board in any future posts.
The following 9 users liked this post by GGG:
aholbro1 (09-23-2015),
AlbBolivar (09-23-2015),
BigBossRadio (09-23-2015),
Don B (09-23-2015),
Grant Francis (09-23-2015),
and 4 others liked this post.
Don B (09-23-2015)
Remember someone on here is asking for help, the least someone can do is make it easier for the people helping them so they can possibly get the best help possible.
The following 2 users liked this post by AlbBolivar:
BigBossRadio (09-24-2015),
Jagboi64 (09-24-2015)
At the moment I have no idea what his car is doing because I don't understand the question; so cannot offer any intellegent suggestions that might help. Anything I say would be a stab in the dark, and that's not proper diagnosis.
Im still here its when I asked for help it seemed like you guys wanted to nit pick my grammer instead of helping me so I jus sat back an watched what everyone said I have no problem answering any question you ask but I dont need to be belittled or judge I was writing the post before I was getting on flight tried to give as much as I could before I have to turn my phone off sorry but if anyone can help I appreciate it if not jus dont reply thats all I ask if you guys need more info im here it might take a day or 2 cause of my work but I will get back to you thanks alot an apologize I did however replaced the battery still didnt help I didnt know if it had something to do with the throttle postion sensor it was replaced but heard it needed to go back to dealer for reprogramming? ??
You need to slow down and organize your responses. Your lack of punctuation in your posts makes it very difficult to understand.
What exactly is wrong with the car? What are the symptoms?
What work has been done to it? This is critical information, and it sounds like you have been leaving some info out.
Do you work on the car, or do you have a trusted mechanic?
BigBossRadio (09-30-2015)
