1997 jaguar xjr v6 supercharged...problems
Old 09-22-2015, 06:27 PM
derek15301xjr's Avatar
Default 1997 jaguar xjr v6 supercharged...problems
Ok i recently bought this car from a guy that couldnt find out the problem with the car an gave up it was a good deal so i took it. car interior is perfect an the outside is in good shape jus a paint job. drove fine for the first couple days then the tranny light came on then it went into a bucking mode so i turned the car off then back on an the light went off drove fine next day same problem i put the car in neutral turned the car off then back on the light went off then i put it into gear an it drove fine again. so after that a couple months went pass an it would go back into bucking mode a few times then one day the check engine light came on so i hooked it up to a reader and 4 codes appeared (p1775 manfac tran control) (p0730 gear ratio incorrect) (p0139 02 sensor)and (p0122 pedal positioning sensor) so i dont know where to begin can anyone steer me in the right direction thanks
Old 09-22-2015, 06:47 PM
Car only starts when it ants to now lol but runs when it does but try to restart later an will not start but tries to
Old 09-23-2015, 03:07 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Say, Derek. If you were to figure out how to add some punctuation and sentence structure to your post, you would probably get better response!
The following 3 users liked this post by sparkenzap:
Don B (09-23-2015), labcoatguy (09-23-2015), RJ237 (09-23-2015)
Old 09-23-2015, 05:31 AM
Im tryna get help on a vehicle not goto english class so if you have any advice that would help please let me know other then that keep your bullshit to yourself an if your are really tryna help me but cannot understand what I wrote please let me know other then that thanks for the reply but it it not meant to help me out then keep it to yourself thanks
Old 09-23-2015, 05:54 AM
OWRltd's Avatar
We are tryna help! I think it funa beez a bad whealz sensor.
Old 09-23-2015, 06:10 AM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
Your symptoms could result from a weak battery. Check that the voltage is over 12.4 before starting and over 13.5 when running. Poor power and ground connections are another possible problem.
Old 09-23-2015, 07:19 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
We behave in a civilised manner on the forum and treat each other with respect. This is the first and last time you respond to a veteran forum member in that manner.
If you wish to remain here then take the suggestion on board in any future posts.
The following 9 users liked this post by GGG:
aholbro1 (09-23-2015), AlbBolivar (09-23-2015), BigBossRadio (09-23-2015), Don B (09-23-2015), Grant Francis (09-23-2015), jimbov8 (09-23-2015), labcoatguy (09-23-2015), Malihide (10-08-2015), RJ237 (09-23-2015) and 4 others liked this post. (Show less...)
Old 09-23-2015, 11:58 AM
labcoatguy's Avatar
I blame whoever put that, as you say, "bullshit" V6 into your Jag where a proper straight six should be.
Old 09-23-2015, 04:07 PM
BigBossRadio's Avatar
I'm curious if you have a XJR straight 6 supercharged...... as opposed to a V6?
Old 09-23-2015, 05:00 PM
sparkenzap's Avatar
Derek:
I promise you I will keep my suggestions to myself!
Don B (09-23-2015)
Old 09-23-2015, 07:54 PM
RJ237's Avatar
Ross, I expect he will not be back, unfortunately. But I don't think I have seen a post that difficult to understand and you were certainly not out of line in your response.
Don B (09-23-2015)
Old 09-23-2015, 08:33 PM
sparkenzap's Avatar
Actually, I also hope he returns. It sounds like he could use some good advice to keep his car on the road. We all get a little on edge when our car ia not behaving, so I hope that is what happened to Derek.
Don B (09-23-2015)
Old 09-24-2015, 07:11 AM
littlelic69's Avatar
It seems to me that we have a member in trouble and is needing help. Not a single comment has helped him, and a few have been annoying - even to me sitting on the side lines! We are supposed to be a good helpful community - not nit-pickers!
shaune (09-24-2015)
Old 09-24-2015, 10:07 AM
AlbBolivar's Avatar
The issue isn't the members not wanting to help but it's the lack of punctuation used which tends to make people not want to read it to understand it. Ross has always been helpful whenever he can be. He's helped me numerous times but I try to make my cries for help as easy to read as possible with line breaks and punctuation so it makes it easier for someone to help me.
Remember someone on here is asking for help, the least someone can do is make it easier for the people helping them so they can possibly get the best help possible.
The following 2 users liked this post by AlbBolivar:
BigBossRadio (09-24-2015), Jagboi64 (09-24-2015)
Old 09-24-2015, 03:29 PM
Jagboi64's Avatar
Received 3,145 Likes on 2,080 Posts
That's true, but we need the OP to help us understand what the car is doing and what the problem is before we can help him. Proper grammar and the problem explained clearly and succinctly will allow us to help him quickly narrow down what might be wrong and how to go about fixing it.
At the moment I have no idea what his car is doing because I don't understand the question; so cannot offer any intellegent suggestions that might help. Anything I say would be a stab in the dark, and that's not proper diagnosis.
Old 09-24-2015, 04:58 PM
knightofgold's Avatar
I'm willing to help anyone with keep an XJR on the road, but that first post was an incoherent mess.
Old 09-28-2015, 06:42 AM
Im still here its when I asked for help it seemed like you guys wanted to nit pick my grammer instead of helping me so I jus sat back an watched what everyone said I have no problem answering any question you ask but I dont need to be belittled or judge I was writing the post before I was getting on flight tried to give as much as I could before I have to turn my phone off sorry but if anyone can help I appreciate it if not jus dont reply thats all I ask if you guys need more info im here it might take a day or 2 cause of my work but I will get back to you thanks alot an apologize I did however replaced the battery still didnt help I didnt know if it had something to do with the throttle postion sensor it was replaced but heard it needed to go back to dealer for reprogramming? ??
Old 09-29-2015, 12:25 PM
You need to slow down and organize your responses. Your lack of punctuation in your posts makes it very difficult to understand.
What exactly is wrong with the car? What are the symptoms?
What work has been done to it? This is critical information, and it sounds like you have been leaving some info out.
Do you work on the car, or do you have a trusted mechanic?
Old 09-29-2015, 01:14 PM
JTsmks's Avatar
I think it's been stated more then once, FIX your posts! I want to help too, if I can BUT I'm not about to wade through that slop.
BigBossRadio (09-30-2015)
Old 10-08-2015, 06:53 AM
Not a problem ill fix the post thanks everyone
Quick Reply: 1997 jaguar xjr v6 supercharged...problems
