1997 Vanden Plas - Bit of knowledge needed please
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/788x487/jag1_bc73404383c96e5006c17a4d459cbe052393a45a.png)
Hello all!, My Vanden has 12 total speakers and I have verified the sub is in the deck lid labeled Harman Kardon, Does this mean I have the upgraded radio version?. I have scoured the forums looking to see if anyone has a line on a wiring harness for the advanced system to place an aftermarket stereo. I've also came to the conclusion 6.5" speakers will in face work in the doors. Please point me in the right direction if possible. - Jacob
![Icon Speaker1](https://www.jaguarforums.com/forum/images/smilies/icon_speaker1.gif)
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
The speakers can be repaired yourself as you replace the cone foam and the mounting foam
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf
There have been a few threads about this upgrade, but I don't know of anyone who successfully changed to a new head unit with the premium sound system. There are several incompatibilities. I suppose it's possible given the will and expertise.
There are two main problems with the conversion:
1. The aftermarket adapter for our Jaguar will not properly feed the amplifier; it is only for direct connection of an aftermarket head unit to the existing direct-to-speaker wiring in a non-premium (no amp) car. The original head unit uses different pins to output to the trunk amplifier.
2. It would be even more complicated to maintain functionality of the 6-disc CD changer in the trunk. There is a separate multi-pin round connector for the CD player that fits directly into the back of the original head unit.
Given that you would probably have other inputs available with a new head unit, and possibly a cd player in it, you could do without the trunk cd changer. So just focus on problem #1. A custom wiring harness would have to be made according to the wiring schematics for the amplifier, to match its inputs. We could assume that the inputs are line-level RCA type signals, although I can't confirm that.
I'm sure more discussion will follow. An interesting question to start off with, no doubt. Welcome to the Forums!
Below is the pinout of the Jaguar / Alpine AJ9500A white square connector used in the standard setup . The pins for the lights are the 3 and 4 to be updated later . The white connector map follows but mine does not have the external Harman Kardon amplifier in the rear and the final head unit amplifier ( 2 X Toshiba TA8221 file below ) in the head unit drives the speakers .
The XK8 and the X3083 use the same setup
Speaker repair video $ 8 each in parts :
Speaker Repair Video
There is the subwoofer repair size 6 x 9 also available in this link :
https://www.jaguarforums.com/forum/x...%24%24-189914/
I'm trying to map out an external input jack other then tapping into the cassette output into the main board and using the 8 pin DIN connector with line in relays to make a easier DIY modification for others
The white square connector has a pinout on the circuit board but I haven't tried to hard to remove it to get to the 8 pin DIN pinout
The LCD typically ghost out and the driver is available but the display is not so I'm developing a repair for that using the original LCD part
Editing
Editing
The following 2 users liked this post by Lady Penelope:
Mark Murphy (01-23-2018),
SleekJag12 (01-23-2018)
Below is the pinout of the Jaguar / Alpine AJ9500A white square connector used in the standard setup . The pins for the lights are the 3 and 4 to be updated later . The white connector map follows but mine does not have the external Harman Kardon amplifier in the rear and the final amplifier ( 2 X Toshiba ) in the head unit drives the speakers .
Editing
Editing
Yes I can! The inputs are Low Level ("line level" as I described them) according to the schematic, on the pinout/connector description page for Figure 18.3. That's why they are in a shielded cable, of course!
Getting very close!, I'm excited. Today I installed a backup camera dashcam combo that uses a new rearview mirror with a screen in it. It works very well and the install is flawless. I did notice I have no tweeters in the deck lid tweeter holes, I'm wondering the they're vents or some models had tweets in them?.
Arriving tomorrow by 8PM
Wednesday, 24 January
8:08 PM
Parcel left the carrier facility
Commerce City, CO US
4:50 PM
Parcel arrived at a carrier facility
4:01 PM
Louisville, KY US
11:57 AM
Parcel received by carrier
Louisville, KY US
11:53 AM
Initiated customs clearance process
Louisville, KY US
10:53 AM
Philadelphia, PA US
10:36 AM
Louisville, KY US
8:37 AM
Philadelphia, PA US
6:53 AM
Philadelphia, PA US
3:53 AM
East Midlands Airpor, GB
Tuesday, 23 January
11:12 PM
10:20 PM
9:51 PM
Tamworth, GB
7:15 PM
Tamworth, GB
Parcel has been handed over to the carrier and is in transit
GB[/SPOILER]
8:08 PM
4:50 PM
4:01 PM
Louisville, KY US
11:57 AM
Louisville, KY US
11:53 AM
Louisville, KY US
10:53 AM
Philadelphia, PA US
10:36 AM
Louisville, KY US
8:37 AM
Philadelphia, PA US
6:53 AM
Philadelphia, PA US
3:53 AM
Tuesday, 23 January
11:12 PM
10:20 PM
9:51 PM
Tamworth, GB
7:15 PM
Tamworth, GB
GB[/SPOILER]
Good eye - the rear tweeters were relocated to the rear door panels with your premium audio. Also the front tweeters went from the dash to the A pillars. Different, yes. Better, not sure. FYI, the service manuals refer to the audio systems as ICE: In-Car Entertainment. So you've got Premium ICE!
Neat option and good idea for a back-up cam. Looking forward to hearing about whatever is in that package!
loveatfirstsight
05-29-2011 01:42 PM
PRB3773
07-21-2010 09:45 PM
DonnaJag
11-14-2007 05:23 PM
