1997 vdp big probs
Guest
Posts: n/a
my jag dies alot now,and seems worse at night.
ran like a champ for ever and ever.
replaced fuel filter,didnt help much.
i notist that when it desides to go south on me,the alt. needle seems to jump a bit.
went to autozone and used there computor diagnostic thingie....here are the codes.....
PO-411
PO-300
PO-304
PO-1316
PO-1314
i live in a very small town in Okla,and other than Billy Joe Bob,There aint alot of people even seen a Jaguar,so looks like i am on my own!
Can anyone help me?
my email is gdrum88@yahoo.com
thanks for any help
Gary Pelfrey
PO-411
PO-300
PO-304
PO-1316
PO-1314
Can anyone help me?
thanks for any help
Gary Pelfrey
The good news is these AJ-16 straight-six engines are bullet-proof, but sadly the bits that surround them are not ! One of the failure points is the plug coil over each plug. In the UK these are known as a regular failure item. Other things that fail are the crank position sensor, and the camshaft position sensor.
I assume by "alt. needle" you mean the volt meter on the dash. This could indicate the alternator is on the way out, but suggest you check voltage at the battery +ve terminal both engine stopped, and engine running. There should be around 2 volts difference.
I cannot translate the fault codes, you need someone more expert than me.
and about 13.5 volts with engine on.
Fletch44
09-28-2015 02:21 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
