1997 X300 boot lock
Guest
Posts: n/a
1997 X300 boot lock
Hi chaps
The electronic boot open button has failed on my 1997 x300 (ie thebutton on the bootlid itself). The other boot release button on the dashboard within the cabin has also stopped working at the same time. I can open the boot manually using the key, but would like the switches working again. Does anyone know the likely problem/solution?? I presume the button switch is the obvious answer, however would this also cause the dashboard switch to fail??? Any advice most welcome
thanks David
thanks David
Received 10,988 Likes
hello! I have te same exact problem as you. I have checked the wiring, relays and fuses and couldnt find anything! The only thing I noticed was that with the voltage power reader is that I am not getting any power from the yellow/orange wire that connects to the actualator into the relay, but I cannot find out why!! Does anyone know? Thanks.
aholbro1
08-05-2021 05:02 AM
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
42Ajd
12-30-2015 09:45 AM
jagent
09-12-2015 09:10 AM
