1997 xj6 unable to open trunk
Old 01-01-2015 | 12:02 PM
rande's Avatar
Default 1997 xj6 unable to open trunk
Help,
I removed my battery to replace it and the trunk closed. the key doesn't do anything when i turn it to the right. I believe the linkage was not properly connected when the body shop replaced my trunk lid.
I looked behind the license plate into the slots for the vertical linkage, nothing there.
Any other ideas?
Rande
Old 01-01-2015 | 12:40 PM
Don B's Avatar
Hello Rande,
Welcome to the Jaguar Forums!
I have moved your post from the forum for the X350 to the forum for the X300, which is the Jaguar factory code for your '97 XJ6. Here your post will be more visible to owners of similar cars who may be able to offer suggestions for overcoming your issue.
Since we're a friendly bunch around here, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can give you a proper welcome and learn something about you and your Jag.
I hope one of our members is able to help you open your trunk.
Cheers,
Don
Old 01-01-2015 | 02:30 PM
Doug's Avatar
On the left and right fenderwells in the engine bay there are small junction boxes that have a "+" post. You can hook up a battery charger or jumper battery to provide voltage to operate the electric release. There are "+" posts on the firewall as well. You'll see 'em under rubber protective boots.
In most cases the key operated mechanism has just seized up from lack of use. Once you get the trunk open just lubricate the manual key lock linkages with your favorite aerosol lubricant. I make it a point to exercise the key mechanism whenever I service the car. This keeps the linkages operational even though I almost never use the key lock.
Don B (01-01-2015)
Old 01-02-2015 | 12:33 PM
rande's Avatar
Doug and Don,
thanks so much for your help. it worked exactly as you suggested.
Rande
Kevin Burnaby
06-28-2020 09:04 AM
rusty37
04-05-2020 08:40 PM
dsnyder586
04-04-2019 03:38 PM
martybmw
04-02-2016 05:55 AM
Chet Ramnarain (bozzner)
09-03-2015 01:21 PM
