1997 XJ6 Vaden Plas X300 ABS module harness bolt
Hi
The bolt that fastens the ABS harness to the module will not loosen.
The bolt turns to no effect. I am guessing either either the internal fastening sleeve is spinning or the bolt is stripped. I have attempted applying outward pressure to harness as I turn the bolt no luck. I have also used pliers to pull backward on the bolt and then apply the ratchet again no luck.
Any advice would be appreciated.
I am hoping to avoid drilling or cutting it out due to all the surrounding wires and tight space.
The following 2 users liked this post by journeyman:
Joedudejag (11-04-2014),
MikeyB10 (01-21-2015)
aholbro1
08-05-2021 05:02 AM
rusty37
04-05-2020 07:40 PM
al_roethlisberger
09-11-2015 10:04 PM
