1997 XJR driver seat, how to replace module?
It is right up under the seat toward the front, and as I recall it is held in with one screw at one end that once removed allows the module to just slip out.
I think you have to unbolt the front of the seat, and loosen the rear, so you can lift the front to get a stubby screw driver up under the seat to unscrew the screw.
And of course you have to unclip/unplug the two harness connectors.
WTB[SouthWest]: 1997 XK8 Transmission - Lower Milage
pilot435
04-16-2016 12:53 PM
