1997 XJR gear selector linear switch
Received 10,914 Likes
Thanks robxjr6 and Doug for that information and i will check the Crank Sensor. Some more light on the situation is when turning the ignition too positon 2 the " P " on the selector does not light up and the when the gear slector is in normal P position it does not do anything, yet pulling back on the selector engages the the switch and the car begins to turn over. I have read on here that it can be caused by the Linear Switch and some gental re-alignment can resolve this, which is why i was aiming in that direction of a possible fault. Thanks Jagxjren.
