4.0 engine custom air intake setups?
Hi all, I am a new member but have been reading for over a year. I have a 1996 XJ6 and want to build a custom intake for it. I have Andy's bracket on the way and want to put the finishing touches on the upgrade.
I have searched the forum up and down but haven't seen a definitive guide yet members have stated they have made some custom setups.
Can I request we make this a custom air intake sharing thread with pictures and ingredients to cook up a peppier kitty?
I had read somewhere (Jag Lovers?) where some testing showed that a good option was to increase the stock "snorkel" on the stock airbox with a larger smooth hose and eliminate the "trumpet" restrictive shape of the OEM part.
I think there also was a post somewhere that suggested adding a second hose/snorkel to the stock airbox and routing both to cooler air forward of the relays and perhaps into the fender were good solutions.
Although I really like the look of the cylindrical filter and custom heat shield above, the options mentioned above would maintain the stock look while negating any need to fabricate a heat shield to overcome engine compartment heat (HAI = hot air intake)![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Interestingly I have "pod filters" and "velocity stacks" on my Moto Guzzi, but several years of testing have shown that the stock airbox actually produced more HP/torque!
Here are some interesting videos on the subject, perhaps not authoritative, but interesting none-the-less:
There are also have been some observations here that suggest the oiled cotton gauze filters (e.g. K&N) aren't a good fit for the XJ air flow sensor as it uses a "hot wire" sensor that the oil fouls. This has been reported on other cars of a similar mass air flow sensor design with oiled filters.
K&N however disputes this: K&N Mass Air Flow Testing Findings
With all of that in mind, I plan to modify my stock airbox with two smooth intake tubes routed to some cooler air, and maintain use of the paper filter.
countyjag (03-12-2015)
Interesting videos Al, and I will be interested to hear how you get on. I have a feeling that if any worthwhile gains were available, Jaguar would have availed themselves of them. In anticipation of the usual comments about Jaguar penny pinching, I can't help but feel that the cost of any extension to the airbox at the point of design would have been negligible, and would not have stood in the way of additional horsepower had it been available. And of course the more the intake is exposed to the airflow, the greater the prospect of ingestion of everything else in the airflow, most particularly water.
al_roethlisberger (03-12-2015)
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Although the video above in the very specific case of that car with that airbox on a NA car did show a gain. The others of course did not.
I still plan to add a little more intake capacity to the stock airbox though. I won't have an opportunity to dyno the car at all, much less before/after under controlled variables.... so ultimately no matter what I observe subjectively, it won't be reliable other than my "butt dyno"
But that's usually the case with these things right?
Received 10,952 Likes
If nothing else you might end up with a very satisfying snarling sound....as Jaguar (as usual) made things a wee bit too silent.
The XJR system varies from the standard XJ6 system only in the diameter of the intake tube. I mention this only because you might wanna keep the original system intact and buy a cheap used XJ6 air filter box to modify and experiment with
al_roethlisberger (03-13-2015)
I am one of those guys that keeps any original OEM parts in a bin in case I ever want to put it back stock.
