4 port ABS bad
Hello pls read carefully. I have a bad ABS (the dash ABS LOCK TRAC FAIL light is on; brakes work fine; *all 4 wheel speed sensors are good with good output*) The ABS on mine is the 4 port version which is generally unavailable/ a lot more dosh than the 3 port. Is there a modification to allow a 3 port version ABS replacement to be used instead of the 4 port?
Failing that, assuming the modulator is okay, can I use the module from a 3 port on a 4 port? Failing that is there a way I can get the ABS warning light off? The brakes work fine, and again, all 4 wheel speed sensors have been cleaned, tested, and are good. regards
I am not aware of a way of going from 3 to 4.
Years ago, my 3.2ltr got the hissy fits with lights, false ABS activation, etc, so I reached up and removed the bulb. NOT everyone's way of fixing things, but, like you, the brakes were fine, and nothing sinister happened.
Had the module repaired, and refitted, and replaced the bulb.
Daily driver, ya gotta do what ya gotta do.
The 4 port is not available, the idea is to go from 4 (BB) to 3 (AA).
But the problem is not the pump/ modulator, it is with the controller, so will send the LNA2210-BA
module to a repair shop that rebuilds these.
BTW there is one '95-97 BB 4 port ABS modulator and control module on ebay (used) asking 499.95.... 2 sold and 1 remaining! lol.
Grant Francis (09-22-2019)
Radical Idea, but why not just find someone with the proper tool to read the codes? Not sure how you can be so confident of the integrity of the wheel speed sensors without reading the codes, but yeah, the odds are it is a C1095. If so, a relatively cheap/easy DIY with plenty written and pictured here on the forum.
That's fine as far as it goes, but that isn't checking the wiring all the way to the module(s) - I believe the left rear feeds the ECU for the speedometer as well, nor whether or not the module is interpreting it as a valid in-range signal. I suppose there are "bad" modules out there that have a problem that is not the C1095 motor pins connection, but I've not seen any reports of such. It is certainly rare, if at all, that they fail in some other way.
I can see where a company would be reluctant to take it on, as it is a "critical function" module and they probably don't want the burden of liability. As you noted, it is "sealed" therefore the first step in repair is cutting it apart. Ultimately, what is cut open must be sutured in some manner. Perhaps that part of the process coupled with the critical nature of the function it serves deters them. Not sure why the Canadians are willing to take it on.
It's rare as hen's teeth, and things get lost in shipping. Just sayin'
Received 13,255 Likes
The Electrical Guide for your specific model (always helpful to post that info) shows the pins each wheel speed sensor connect to at the ABS Module. You can download the appropriate manual at jagrepair.com courtesy of our member Gus, who also has some excellent resources on repairing the ABS Module.
The most common cause of failure within the module is cracked solder joints at the two large pins that power the pump, but on nearly all the modules I've repaired I have found cold or starved solder on lots of the smaller joints including the ones at the large connector where the wheel speed sensor signals arrive, so I just reflow and supplement every solder joint I can access. You'll find some repair methods that involve drilling a hole in the ABS Module case above the pump connector pins, but I highly recommend just sawing the entire back cover off so you can access all of the solder joints.
Cheers,
Don
Cafcpete (09-24-2019)
XeModex did excellent work repairing the LNA 2210BA . Module sent to Ontario Canada from the US, Xemodex had it next day, repaired and out the door back to me, received the following day! Very impressive and of course fixed my ABS issue.
The express service is twice the standard shipping cost, but well worth it, imo. Luckily there was no tariff to pay across the border... but a shame that no US company can (or will) repair these! (at least not any that I contacted) Sad!
aholbro1 (09-26-2019)
daboss085
04-07-2012 03:24 PM
