95 Vanden Plas blown air pump fuse F7
Hey all,
I am in the process of fixing my 95 Jag and I still have one code to clear. Its the pesky P0411 code. The first thing I did was check the fuse and it was blown. Changed fuse started car and then turned off, fuse blew again. Im thinking new air pump but not sure. Also where is the air pump located? I would most likely change the check valve and hoses as well.
Any thoughts or experience with this would be helpful,
Thanks!
Thanks!
Pumps are known to fail...again...and again....and some more. Reportedly the same pump as used on some vintage of corvette, or another. It is on left side, front of engine, right next to the water pump and near the thermostat housing. Look at the bottom of your air cleaner box and find a 3/4" dia or so flexible hose....follow that for about a foot or so and you'll arrive at the back of the air pump.
chazzWARD
31
12-04-2021 09:02 PM
