95 XJ6 front door panel
What I discovered was simply a VERY strong clip right in that area. I just had to pull REALLY hard, and it finally gave. The clip ended up coming out with the white plastic piece it secures into, which inevitably somewhat broke. To reinstall, I removed the white plastic piece from the clip on the door panel, installed it into the door, and then installed the door panel. It is sill very rigid and secure.
Anyway, I just pulled the thing straight off. The plastic piece got badly broken, and I even bent the metal panels it slots into (they'll bend right back though).
How not to do it:
![](http://img263.imageshack.us/img263/6701/dscf3988d.jpg)
^ if you look closely, you'll see that the metal edges are bent slightly (by the way, that gnarly cutting job on the grey insulating foam was Jaguars doing - what do they use, their teeth?)
![](http://img263.imageshack.us/img263/1827/dscf3991b.jpg)
So now I have to find a replacement for that plastic bit. Any ideas? I can see it listed in any stores...
99xk8guy
06-05-2023 06:28 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
