95 XJ6 front door panel
Old 06-06-2010, 01:18 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Give us a few pics of the armrest, top, bottom and side..we'll find your screw!
Old 06-07-2010, 12:11 AM
Oubadah's Avatar
Is there any way to remove that bit between the armrest and tray?
Old 06-08-2010, 08:54 PM
daveoby's Avatar
What I discovered was simply a VERY strong clip right in that area. I just had to pull REALLY hard, and it finally gave. The clip ended up coming out with the white plastic piece it secures into, which inevitably somewhat broke. To reinstall, I removed the white plastic piece from the clip on the door panel, installed it into the door, and then installed the door panel. It is sill very rigid and secure.
Old 06-09-2010, 04:00 AM
Oubadah's Avatar
Yes, I just got impatient and hauled on the thing. Made a right pigs **** of it too. It was lift up an off after all, but for some reason it wouldn't move upwards before - maybe I wasn't trying hard enough.
Anyway, I just pulled the thing straight off. The plastic piece got badly broken, and I even bent the metal panels it slots into (they'll bend right back though).
How not to do it:
^ if you look closely, you'll see that the metal edges are bent slightly (by the way, that gnarly cutting job on the grey insulating foam was Jaguars doing - what do they use, their teeth?)
So now I have to find a replacement for that plastic bit. Any ideas? I can see it listed in any stores...
Old 06-09-2010, 07:54 AM
H20boy's Avatar
I'd try some mega epoxy, if you still have the extra pieces lying around.
Old 06-09-2010, 08:54 AM
Received 1,231 Likes on 716 Posts
Looks to me as though you might still have enough left unbroken, to hold the thing in place as it is.
Remebering that you have all the other pannel clips and screws as well.
Failing that, what about swapping it with one of the lesser used rear doors, if they are the same?
99xk8guy
06-05-2023 06:28 AM
PMKimpton
08-03-2019 08:22 PM
bdboyle
09-04-2015 06:16 AM
obwoodie
09-03-2015 07:45 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
Quick Reply: 95 XJ6 front door panel
