95 XJ6 Hit a curb, blew both drivers side tires, car wont start
I hit a curb last week and blew both driver's side tires, didn't bend the rim thankfully. Got the tires replaced and remounted. Started the car and drove 100 feet and parked it. 4 days later went to move the car and it won't start. Turns over but no ignition. Going to try the inertia reset first. What is second?
Inertia switch doesn't always mechanically reset and can be fickle . It can be bypassed with paperclip across both white wires . Works for me .
Yes on the full battery charge before hot wiring the inertia switch and listen for the fuel pump for the first 3 -5 seconds as it primes the fuel rail and turns off by design . This occurs before you hit the starter key position as you have the key in the run position . The fuel pump will come back on as the ECU sees engine rotation
Did you put a paper clip in the inertia ( kill ) switch connector 2 white wires ?
You can hotwire the fuel " on " at all times by taking positive power to the output socket of the fuel pump relay . Use a blade connector on the socket and be careful of high current arcing damage to the relay socket by connecting with a heavy wire to the power source last . It is the FWD relay socket slot wire color Red / Yellow as you can pull up the relay tray and see the wires .
Just speculating , may have trapped enough fuel pressure in the lines to give you the 5 second start then stall immediately after the accident , but it's not replenishing .
Pull a plug and ground ( jumper cable to engine block or frame ground stud will work ) to see if you have spark .
