95 XJ6 Sudden Compressor Quit
I am going to go through the manual for the fuse location here in a bit.
Could it really be low on refrigerant even when it was cooling so well just prior to it not working?
JB:
The fuses involved are #8 and #10 in the RH engine bay box. The clutch relay is in a group of three immediately behind the RH headlamp. It is the one of the three towards the center of the car. If you have don't figure it out right away, get a 12 volt test lamp and check back for more.
Good luck
Good luck
Received 2,190 Likes
Last year the clutch on my compressor died. I ended up replacing the entire compressor and clutch assembly. I sourced a real Denso compressor from a Jag parts place just outside of Houston TX for approx $300 and had it shipped to my home in Canada and fitted by a local AC specialist. Ran the car today for the first time since October and I still have ice cold AC.
Guy-Pierre Boucher
09-16-2015 05:55 PM
