96 jag vdp vin 7 usa Power steering and radiator questions
so im replacing the whole power steering system
on my 96 jag vanden plas vin 7 usa LHD 220k miles on it
I have already received these parts
1996 Jaguar Vanden Plas Power Steering Pressure Hose - W0133-1609096 Eurospare - $75.48
Qty Ordered: 1, Qty Shipped: 1
- Fri 04/28/2017 12:11 AM
1996 Jaguar Vanden Plas Power Steering Return Hose - W0133-1616086 Eurospare - $55.48
1996 Jaguar Vanden Plas Power Steering Return Hose - W0133-1656656 Original Equipment - $75.48
1996 Jaguar Vanden Plas Power Steering Reservoir Line Hose - W0133-1627889 Eurospare - $25.48
AAE 3119V {#M3891ABE} (Remanufactured) Remanufactured; Includes Magna-X Particulate and Magnetic Filter Info
Power steering; Zf W/SENSOR VIN # 720125 On $190
Im ordering today
Genuine Power Steering Reservoir
SKU: W0133-1609579 $143
TRW Tie Rod End - Outer
SKU: W0133-1630438
$27 each
i have to remove my pump and get it rebuilt i guess for $140
i need a radiator ( this car holds power steering fluid in it wtf?)
any ideas on good rebuild services and source for radiator
i was reading the manual says the rack has a locating pin i need to remove and install a plug and washer? where can i buy those?
Im ordering today
SKU: W0133-1630438
$27 each
Hi, not encourage more expense or work, but I had this down a a couple of years ago and then needed to replace the steering rack as well. I got a rebuilt rack from Coventry West about half the price of a Jaguar one. Also, the PS fluid in the radiator is a cooler below that I found out about when the nut was frozen on and broke.
Received 2,193 Likes
Power steering fluid tpye = Dexron IIE ATF if Dexron III not available
Problem = heavy on both sides ( power steering )
Center pressure low
The manual says to set to Specification. How can i do this?
Lower Column incorrectly set . How can i set to specification?
Stiff or seized steering joint. where can i find a diagram and how to test the joint?
Lower column over extended. how can i set to specification ( maybe same as other>)
How to check and fix free play in the column assembly
where can i get new mounting bolts for the rack it says in the manual i need new ones
Center pressure low
ITEM QTY TOTAL
Jaguar Genuine Part Number JZS100046 | Setscrew 5 $4.25
Jaguar Genuine Part Number XR829166 | O-Ring 5 $23.40
Jaguar Genuine Part Number C2C16681 | Insulator 4 $5.60
Jaguar Genuine Part Number JZP100005 | Clip-Rubber 5 $12.75
Jaguar Genuine Part Number MNA3996AA | Pipe 1 $78.20
Jaguar Genuine Part Number JZB100050 | Bolt-Banjo 1 $16.15
Jaguar Genuine Part Number JWV116001 | Washer-Sealing 1 $9.35
Jaguar Genuine Part Number CBC1400 | Nut-Expanding 1 $0.85
Jaguar Genuine Part Number JZP100016 | Clip-Pipe 5 $12.75
Jaguar Genuine Part Number AGU19441 | Setscrew 1 $0.85
Jaguar Genuine Part Number JHC301220 | Clamp-Hose 3 $2.55
Jaguar Genuine Part Number JHC302230 | Clamp-Hose 2 $3.40
Jaguar Genuine Part Number CAC9294 | Gasket 1 $6.29
Subtotal:
$176.39
Shipping & Handling:
$18.70
Tax (9%):
$15.89
Total: $210.98
man the jag just adds up like a ****
Subtotal:
$176.39
$18.70
Tax (9%):
$15.89
Total: $210.98
