'96 sunroof parts needed
I am in need of the small plastic pieces which allow the smaller interior sunroof piece to move. One side of mine is broken. I have two used sunroof rail pieces but they did not come with these pieces. I tried Jagbits, (that was the source of the used rails, but they do not have them). Anyone have any ideas where to source them? My plan is to redo the headliner at the same time.
Ed
Ed
https://www.jaguarclassicparts.com/u...ixings/sunroof
Are these the items ? Should be the same as X308s and may find some resources in that area of website
HNA1752AA - JIPARTS ONLINE / ??????? ??????? ??????? ??????? ??????? ???????????MG ???? ???BMW MINI ???? ???? ????? ?? ??? ?? / LANDROVER DEFENDER FREELANDER SPORT EVOQUE RANGEROVER MG ROVER BMW MINI JAGUAR PEUGEOT CITROEN PARTS
1998-2003 Jaguar XJ8 XJR Vanden Plas OEM Left Side Sunroof Slide Mechanism Assy NEW HNA1753AA HNA1759AA HNA1755AA: Jaguar Used Parts, Auto Body Supplies, Salvage Car Wrecking Junk Yard
When I pull mine apart I will need some items myself
I don't know if you can get JUST the plastic piece that connects the interior sliding 'drip-tray' to the tilt/slide mechanism in the tracks. It was always sold as a complete unit LEFT or RIGHT.
When I worked at the dealer I thought it was stupid to replace the entire tilt/slide LH or RH but that is what we had to do.
I saved all the good used ones that I got from otherwise broken mechanisms. They are long since installed in other cars.
bob
Lady Penelope (10-11-2017)
Left side # HNA1753AA
Right side # HNA1752AA
Might be possible to repair the original broken plastic pieces with some high quality JB Weld 2 part adhesive with the use of some embedded threads for some added tensile strength . You can play with it before sourcing a replacement part . Ensure you sand the original part surface for better adhesion and if you apply too much materiel it simply sands of files off just keep the reinforcing threads close to the original material by maneuvering with a toothpick . Notice the different cure times as the yellow one sets too fast to maneuver your repair around . The full cure time is important in that from experience this completes the original surface adhesion ( and can be used as a early release time if you are molding something )
Take pictures and will help many if successful
Sunroof
My 97 donor car has a sunroof but my daily driver doesn't. So, I have all of the parts available, except for a module which I sent off to another forum member.
If you can post a pic of the parts you need, just so I can recognise them, I'll dig them out. Pm me an address and I can pop them in the post. You're more than welcome to them and maybe you'd care to give a few dollars to some charity of worthwhile cause of your choosing?
Scotlad (10-13-2017)
Below is a pic using paint putting in arrows in the area of interest . Mine is out of rig in that the top panel is 1/2 inch from closing as the previous owner had sealed it shut with sealer . I put the my sunroof on hold but decided to open that can of worms to repair it together . My motors do move the side rail parts around but come to a interference stop as they hit . It is suppose to rain heavily here Saturday and my pipes are off and and car outside so let me remove the headliner tonight to get my eyeballs on it then cover .
I will modify your pics as we go through this
My inner panel is missing as the previous owner didn't have a clue and just punted . Along with the panel missing is the sliding rail (F ) I assume with the attach point ( E ) you say is broken on yours . I do have the metal arm it attaches to . Will have to source some parts before proceeding . Kept it sealed and looked from the bottom and this reference pic is from someone else
For yourself you might find the correct size brass tubing from a model airplane shop to be used as a bushing and build up the rest with the epoxy shown above . You can use a wooden dowel to line the bushing correctly and I would not expect to fully glue it up in one setting but just a tack to position the bushing in place and then fill in the rest of the pivot point void in later steps . With this you can use the short time cure as the longer will run all over the place before the set time before the complete cure time .
Let me know how it is cracked behind the pivot point and we'll see if a repair can be mapped out
Being out of alignment may be what caused it to break and is addressed in Jaguar TSB below :
I will be looking for a outer seal before I paint her if anyone knows a source HNA-1727-AE Sunroof Seal, 96- on ? Found it below :
https://www.jaguarclassicparts.com/uk/part/HNA1727AE
From memory, I thought this panel was fitted at the front end of the opening. I could be wrong on the wrong track entirely. Let me know and I will get it sorted.
That shouldn't be a problem. I can send both sides, as I should have them both. No harm to have a spare! As for the rear panel you mention, can you clarify this? Is it the inner roof/ceiling panel? The one that sometimes goes astray up inside the roof cavity?
Ed Preusser
667 rt 9d
Garrison NY 10524
USA
THANKS!
Sunroof parts
I'll sit tight until I hear from you and then they'll be on the way.
someguywithajag (10-17-2017)
Just want to clarify things before I put anything in the post. I've attached pics of the two brackets/clips that you enquired about. Hope they do the job. On one of them, you might notice a small part of the tang on top is broken off, but this didn't seem to impact in any way. I've also included a pic of the part of the sunroof panel, which I think is what you need. You might just confirm same before I post them and if there are any other bits of the roof set up that I can post, let me know.
I scoured many a junkyard and asked a lot of people on eBay but I couldn't find one. I eventually did get a hold of one by buying an entire sunroof.
Anyway, now that I have them, do you know how to properly set the sunroof back? I put in those black bits by partially removing the headliner but the sunroof itself is not set properly. So I can't open or close it. I ended up just disconnecting the motor until I found a solution...
That makes life simple! I can pop them in a jiffy bag tomorrow and send them on their way. Let us know when they arrive and hopefully you'll have lots of opportunities to enjoy your sunroof. Here in Ireland it's as much a luxury as air con!
From a X308 post which is the same :
PS - the original post also includes links to Lincoln LS parts to replace broken sunroof sliding mechanism and How-To by Ragsman, which can save you about $1,000 in labor.
https://www.jaguarforums.com/forum/x...properly-4140/
And the larger post :
https://www.jaguarforums.com/forum/x...solved-185342/
