96 Vanden Plas Climate control Problem
Old 10-29-2012, 02:10 PM
lrover76's Avatar
Default 96 Vanden Plas Climate control Problem
Hello,
I'm having problems with my climate control system. When i cycle the key to on or run, the cooling fans come on, Does the system default to run the fans if a sensor has failed? I have also replaced the circulation pump and toyed with the valve, the Climate control system does work, aside from the controller not telling the cooling system valve and pump to operate.
Any thoughts and or ideas would be great.
Cheers B
Old 10-29-2012, 03:33 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
Scroll down to my post of 10/24 "cooling fan 95 XXJ6" for info on the fan.
Old 10-29-2012, 09:33 PM
Received 8,076 Likes on 4,871 Posts
Are there any DTCs in the module??????????
bob gauff
Old 10-30-2012, 01:12 PM
lrover76's Avatar
Default Dtc..
Hello Motorcarman,
I have checked the DTC the only code are 24 Face Vent Potentionmeter
O/C OR S/C HIGH S/C LOW
AND CODE 23 Refrigerent Pressure Switch Low Gas Charge or O/C OR S/C HIGH
OR S/C LOW..
XJsc-guy
09-25-2015 11:09 AM
tberg
09-07-2015 07:32 AM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: 96 Vanden Plas Climate control Problem
