96 VDP speedometer and anti-lock problem
Found out the speedometer works intermittently, and the anti-lock light on and off along with it.
Seems the speed sensor on the differential or its wiring?
Anyone knows if the ABS speed sensor will feed output to speedometer?
I am not sure which is next step...
Your model does not have a sensor in the differential. The ABS module sends the instruments a speed signal based on the LR wheel speed sensor. I seem to recall someone in training saying that if the ABS lost the LR sensor, it would then use the RR sensor. I can't prove that, but that's my recollection.
Good luck.
Good luck.
Received 2,193 Likes
You need to see what codes are stored in the abs control module, cause it could be sensor, wiring, module etc... If the abs module looses communication, power, ground, signals, you get no speedo. Yes the abs module sends the cars speed to the instrument pack. Dont just assume its the sensor/s.The first thing you could do as a DIY is pull the abs wheel speed snesors out and clean them. disconnect and reconnect the electrical connectors as this cleans pins a many times fixes a intermittent signal since the pins can get unseen corrosion and the simple action or disc.reconnect cleans and reestablishes a good connection.
youll need a code reader that can do abs, theyre out there and you can try the auto parts stores to see if the one they use is capable. I know i saw 1 in oreilly yesturday that said abs, and can capable>>of course it also said $200
Cleaned rear ABS sensors, problem persist.
I noticed a pattern of the anti-lock light:
1, when it is on when cold start, once the speed is above 10 MPH, the light comes off and the speedo works fine;
2, once applied brake when speed below 10 MPH, the light comes back again until next cycle.
I am skeptical about the ABS module circuit board - seems a bad capacitor some where.
I will go oreilly for the reader and try to pull out the code.
Put the back of the car on jack stands and unplug the link lead to the lr spd sensor. Using a dvom set to ac put the car in drive(remember i did say rear of car on jack stands) and with the wheel turning you should have ac voltage. If not disconnect the link lead and test for continuity, if you have cont. Replace the sensor, it bad. If you have a ac signal your issue is the module or the wiring in between
Update:
Currently the ABS light occasionally on the first start after parking for 1-2 days.
It will be off next start.
The speedo works good after I have cleaned the sensor.
Had a new sensor on hand, but just want to see how long will the old one last.
Brutal, thanks and I will do the diagnose before I actually replace the old sensor.
If not, follow the lead back up through the floor into the space beneath the rear seat. To remove the rear seat, remove the two heelboards and unscrew the teo screws, one each side, that hold the seat brackets in place.
Pull the seat upwards and out, feeding the seat belt mountings through on the way. Beneath the foam lining you will find the other end of the lead and its' connector. The lead will be cable tied along the way, usually around the brake caliper and brake line. Remove these and remove the lead and sensor attached, complete with the rubber grommet where the lead passes through the floor.
It's no harm to spray some wd40 or similar around the sensor before removing as they can become stuck and the top can shear off if you twist it, while thinking it's coming free.
It is possible to lever the sensor up from below, by inserting a thin flat bar, (like a largish spanner) into the space beneath the sensor, from the inner side of the hub assembly. Just feel around and you will see what I mean. The left rear sensor also feeds the signal to the speedo, just in case yours is acting up and sometimes a clean up is all thats needed.
The reluctor ring (toothed wheel ) will be visible through the hole, with the help of a light, once the sensor is removed. These teeth can become gummed up with crud and so also affect the sensor signal. Easily cleaned, with a long thin screwdriver or similar, tooth by tooth while rotating the wheel.
Hope this helps. Should take less than 30 minutes.
aholbro1
08-05-2021 05:02 AM
Dicque
09-19-2015 12:53 PM
10, abs, anti, brake, connect, ecm, httpwwwxk8, instrument, jaguar, light, lock, module, mph, problemnet, speedometer, vdp, x300
